Unlock Server
Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 10-24-2011, 10:57   #1 (permalink)
Member: 1676905
4 Band 4W Portable GPS Cell Phone Signal Jammer
  • This product can be used in any place where mobile phones and GPS are prohibited to be used!
  • Cover interface standards: Cell phone signal (CDMA, GSM, DCS, 3G), GPS (1570-1580MHz)
  • Total output power: 4W
  • Effective range: Radius Up to 20 Meters.
  • Work time: 90 minutes, this gps jammer can continue to work when charging,
  • Support being powered by charger or car cigarette charger.
  • Every band frequency can select output power.
  • All the TX frequencies cover downlink only.
http://www.jammerall.com/products/4-...*********.html
The Following User Says Thank You to vallie05 For This Useful Post:
Old 11-23-2011, 07:48   #2 (permalink)
Member: 1694253
As the author has mentioned a GPS cell phone jammer is really very helpful and useful in our life and with a reasonable price! We offer more for you to chose.
Old 06-28-2012, 11:08   #3 (permalink)
Member: 1766174
I absolutely agree with your opinion. but there are a lot of other usages about GPS, I got the GPS jammer and its details from jammerall. it is really a cool website, it helps me a lot.There are some other jammers devices in it. share with you all. you can come and see as you like.
Old 07-17-2012, 10:03   #4 (permalink)
Member: 1785847
Sonork: 23123361
This 4 band and protable cell phone jammer ,can both block all cell phone signals +3G singals as well as GPS signals , It is a sophisticated Low power pocket-size jammer. It can be carried and used everywhere. It can block different RF signals up to 10 meters shielding range. ,more cell phone jammer please come to us :www.gasiajammer.com
Old 07-17-2012, 10:13   #5 (permalink)
Member: 1785847
Sonork: 23123361
This portable cell phone & GPS jammer is design features an internal fan cooler and wind slots on each side, which helps cool down the heat when the jammer is working.This feature makes it be able to work 24 hours continuously without being damaged. It has a great output of power at 2.5 watts and can disable all types of cellular signals including the 3G and GPS signals within radius for up to 20 meters. It"s great for schools, restaurants, conference rooms, museums, and vehicles.
It comes with a leather cover that offers a strong protection for the jammer. There"s also a belt attached on the leather cover so you can take it anywhere you go.
Old 07-17-2012, 10:15   #6 (permalink)
Member: 1785847
Sonork: 23123361
For absolutely jamming cell phone signal, GPS, and 2.4G WIFI Signal, there is
no stronger or more efficient solution than High Power 6 Antenna Cell
Phone,GPS,WiFi Jammer. This high quality device provides you with 15Watt output
power and 6 powerful high gain antennas to completely block mobile phone
signals, GPS and WIFI signal.
Specifications:
Affected Frequency Ranges:
-CDMA 851-894MHz 35dBm 8dBm/30KHz (min)
-GSM 925-960MHz 35dBm 5dBm/30KHz (min)
-DCS / PCS 1805-1990MHz 33dBm 2dBm/30KHz (min)
-3G 2110-2170MHz 33dBm 2dBm/30KHz (min)
-WIFI 2.4G 2400-2500MHz
-GPS 1575.42MHz
Power supply: AC adapter (AC220V-DC12V)
Shielding Radius: (2-50) meters@-75dBm (depends on the strength signal in given
area.)
Weight: 3kg/PCS
Old 07-17-2012, 10:16   #7 (permalink)
Member: 1785847
Sonork: 23123361
High power GPS blocking on the L1 / L2 / L3 / L4 and L5 bands. Switch selectable to cover only the bands you wish to block. Built in fan for constant cooling.
This unit is our top of the line portable GPS jammer.
Charging while working
Each band can work separately or simultaneously
Built-in fans and Wind slots on two sides design and inside coolers make a constant cooling working.
Technical Specifications
GPSL1:1500-1600MHz
GPSL2:1220-1230MHz
GPSL3:1200-1210MHz
GPSL4:1250-1280MHz
GPSL5:1170-1180MHz
Power supply: AC110-240V /DC12V
Built-in Battery: 1800mA/h
Total output power: Up to 2Watt
Radius range:2-15m (depending on the mobile service provider"s network condition)
Built-in battery time: 1hour
Signal source: Synthesized operation
Working temperature: -10 ~ +50 degree centigrade
Relative Humidity: 5%-80%
Color: Skyblue
Device size: 113*60*31mm
Net weight: 0.275KG
*******(NOTE) this is not your own sales sectionn...*****
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 10 03-11-2013 15:27
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-16-2010 04:52
Page generated in 0.44659 seconds with 11 queries
