Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 04-10-2017, 23:15   #1 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
5 pins soldering tweezer convert to 7 pins
Hi!
did anyone knows how to convert soldering tweezer 7pins to 5pins to be use at rework stations ? I cant find to there website or google.thanks in advance
regards,
Old 04-10-2017, 23:24   #2 (permalink)
Member: 168904
Thanks Meter: 23
You must identify the pin 2 of the resistance and the pin 2 of the temperature probe and verify that they are compatible ...
The Following User Says Thank You to fulviospano For This Useful Post:
Old 04-12-2017, 17:39   #3 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
do you have a schematics or diagram,sorry can't find any.
Old 04-12-2017, 22:25   #4 (permalink)
Member: 168904
Thanks Meter: 23
No sorry. If you want you can post photos of disassembled connector so you can see all 'inside as it is assembled.
Old 04-15-2017, 21:59   #5 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
here's some pictures
https://ibb.co/nOTkt5
https://ibb.co/jndULk
https://ibb.co/kMndD5
Old 04-21-2017, 14:44   #6 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
seems all 7 pins are not connected . 4 or 5 pins are connected rests are not connected or idel .
need to know soldering station 5 pins connections . positive pin , gound pin & other temp sensing pins .
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 04-23-2017, 21:43   #7 (permalink)
Member: 168904
Thanks Meter: 23
Well, there are 4 wires in the photos, now you have to find the 2 of the heating resistance and check with a multimeter that the value is the same as you want to put if you do not burn it, the two remaining wires are the temperature sensor here too you have to measure Its resistance if it does not have the same value will not detect the right temperature.
Old 05-03-2017, 06:54   #8 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
U can easly check the pinout of both m. But u need to disassemble and check.
For tweezer seem have double resistorn
Page generated in 0.20110 seconds with 9 queries
