Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 08-15-2016, 06:17   #1 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
Arrow About Smart Heating Platform (SHP)
Smart Heating Platform (SHP) is the best professional toolkit for your electronic hardware repair needs. It offers many indispensable functions and makes working in a professional repair shop much more easy.
Product Description:
  • All functions are finely controlled using our custom made software control system with real time data display
  • General settings and operating ambient temperature ranges can be programmed using our software in order to work with or without computer
  • Has 4 integrated temperature sensors (internal temperature, heater temperature, external temperature and real time temperature tester K Type sensor)
  • The heating system has automatic temperature control that can keeping temperature constant and accurate while you work
  • An integrated 4 digits LED Display that can display all necessary data including state, temperature and voltages
  • A built in temperature tester function that can accurately and efficiently measure solder iron and hot air temperature (Measurement range: -125 - 1200 ℃, Tolerance: ± 1 ℃) in real time . This way you can be sure your rework tools are correctly calibrated and working at peak performance
  • Heating panel A made from high purity copper with an efficient method for high heat flux design
  • Heating panel B made from aluminum can separating glass etc(Compatible size for 13 inch and below)
  • With panel B can use for baking、drying、aging etc (Eg.water-flooded components of UMT mainboard)
  • Almost all current PCB integrated circuits can be soldered and de-soldered without the need of a soldering iron or a hot air gun. (Eg,Apple A7 A8 A9 A10 CPU 、baseband IC or harddisk IC etc)
  • Can act as a pre-heater for your everyday needs to minimize the risk of component damage
  • Smart phones, iPad products's glass lens, touch screens & LCD displays can be separated in a few mins
  • Default factory settings with general working conditions specification (Eg. Glue remove、IC de-soldering & Soldering、lens & touch screen assembly settings etc)
  • Integrated self-resetting overheat protection
  • LED warning alerts and sound alerts
  • Voltage overload protection integrated
  • Short circuit detection integrated
  • Automatic shutdown function integrated
  • All functions are user customizable
  • Lifetime free software upgrades and more
Add-ons Software (Activation required):
  • Working with all Apple product and Huawei Android Mobile Hisilicon based mobile device (Called iMFC)
Technical Data:
  • Operating voltage: AC 220V & DC 5V(USB)
  • Output Power: 300W
  • Temperature Range:Room temperature - 350 ℃
  • Temperature Tolerance: ± 3 ℃
  • SHP Box Size: 226*90*45 MM
  • Heating panel A Size: 58*12 MM
  • Heating panel B Size: 315*220 MM
Package content:
  • 1 x SHP Box Complete Kit
Safety and Technical notes:
  • An electric constantly and accurately heater is a much safer source than an iron or air gun. However, the heaters also get hot and must be handled with care.
To all user,
  • Booking on mfcbox.com today will be get promotion (end date 2016-8-20) price , and all the orders start to shipping will be early September.
  • Reseller are welcome ( Send Email to [email protected] )
Page generated in 0.12874 seconds with 8 queries
