Advice, about Hot air station.. Hi all. Sorry for my english. I would want an advice for purchace station rework hot air + soldering. With microscope, It is better ? Thank you for yours reply 👍 |
hakko frome japan it good choice |
metcal mx-5000 and buy microscope too, very useful for hot air you have plenty of choices cheap and expensive but you dont really need expensive one to rework iphone, I personally use quick products |
Thanks for yours reply. If There are others models , i am waiting my friends |
I found an aoyue 852 ++. It costs about $ 150. have you other tips for a hot air station, with a budget of about $ 150/200. for iron, I'll take the hakko 888. I have the station hot air to find, thanks for your advice. :) |
hi depend how many hours you use the soldering station ..the quality has a price .. I advice for QUICK good for quality / price.( looking your budget) |
Thanks orx, for your reply. I fount this website. Cablesmall.( com Do you think that station is guenine ? Thank you friend. |
hi you are welcome the price is very good anyway, hear other opinions . |
Have you got a link for a pourchace. Quick 861dw. I am in Europe. The main, it is the price. Thanks |
sorry no link , read the rules... anyway , the your site has the best price for this 861DW and i confirm still with shipping cost incluse ,so.. |
Hi. as I think it's important to make a comeback. Here is what I finally bought. the ZD - 939L. I would like opinions on this hot air station? Thank you. I count on you ORX Lool. Thanks |
Hi It is part of the great family of the economic units with low price chinese..not a professional product but it may be good to begin ..with prolonged use you understand the limitations of a low-price station but still .. it is also important to check availability of spare parts in case of breakage. I put a comparison of a professional station with a hobbyist free example low price: Temperature regulated: 150-500°C Adjustable air flow: up to 24 liter per minute The 120g light weight solder iron means you can work longer without tiring. The spring system of the compressor enables relatively untroubled and quiet operation Transportation lock conserves the absorber of the compressor Coated steel plated housing Technical Specifications Input Voltage: 230V, 50Hz Power: 320 Watt Tube length: ca. 1m Dimension: ca. 160 x 148 x 240 mm, (WxHxL) control knob included, without holder Weight: ca. 3.2 kg professional Power 1200W Voltage 220V 50/60HZ Temperature Range 100℃-500℃ Airflow Range 6-200 Max Airflow 200L/min Size(L*D*H) 188(L)*245(D)*135(H)mm Weight 3.65kg |
Finally, I bought quick 861dw. Thanks friend ORX and the others. It is good ORX, this product. ? |
Hi if you talk for 861DW yes sure. anyway , i don't see attachments .. |
