Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 01-25-2017, 22:09   #1 (permalink)
Member: 2676184
Thanks Meter: 5
Advice, about Hot air station..
Hi all.
Sorry for my english.
I would want an advice for purchace station rework hot air + soldering.
With microscope, It is better ?
Thank you for yours reply 👍
The Following User Says Thank You to Hami76 For This Useful Post:
Old 01-27-2017, 06:31   #2 (permalink)
Member: 1699846
Thanks Meter: 21
hakko frome japan it good choice
The Following User Says Thank You to metdelta For This Useful Post:
Old 01-27-2017, 13:08   #3 (permalink)
Member: 2453408
Thanks Meter: 60
metcal mx-5000
and buy microscope too, very useful
for hot air you have plenty of choices cheap and expensive but you dont really need expensive one to rework iphone, I personally use quick products
The Following User Says Thank You to Kradziej For This Useful Post:
Old 01-27-2017, 14:01   #4 (permalink)
Member: 2676184
Thanks Meter: 5
Thanks for yours reply.
If There are others models , i am waiting my friends
Old 02-22-2017, 21:34   #5 (permalink)
Member: 2676184
Thanks Meter: 5
I found an aoyue 852 ++.
It costs about $ 150.
have you other tips for a hot air station, with a budget of about $ 150/200.
for iron, I'll take the hakko 888.
I have the station hot air to find, thanks for your advice.
Old 02-22-2017, 22:20   #6 (permalink)
orx
Moderator
Member: 1825965
Thanks Meter: 593
hi
depend how many hours you use the soldering station ..the quality has a price ..
I advice for QUICK good for quality / price.( looking your budget)
The Following User Says Thank You to orx For This Useful Post:
Old 02-22-2017, 23:27   #7 (permalink)
Member: 2676184
Thanks Meter: 5
Thanks orx, for your reply.
I fount this website.
Cablesmall.( com
Do you think that station is guenine ?
Thank you friend.
Old 02-23-2017, 07:13   #8 (permalink)
orx
Moderator
Member: 1825965
Thanks Meter: 593
hi
you are welcome
the price is very good
anyway, hear other opinions .
Old 02-23-2017, 08:27   #9 (permalink)
Member: 2676184
Thanks Meter: 5
Have you got a link for a pourchace.
Quick 861dw. I am in Europe.
The main, it is the price.
Thanks
Old 02-23-2017, 09:04   #10 (permalink)
orx
Moderator
Member: 1825965
Thanks Meter: 593
sorry no link , read the rules...
anyway , the your site has the best price for this 861DW and i confirm still with shipping cost incluse ,so..
Old 02-28-2017, 05:46   #11 (permalink)
Member: 2676184
Thanks Meter: 5
Hi.
as I think it's important to make a comeback.
Here is what I finally bought.
the ZD - 939L.
I would like opinions on this hot air station?
Thank you.
I count on you ORX Lool. Thanks
Old 02-28-2017, 07:33   #12 (permalink)
orx
Moderator
Member: 1825965
Thanks Meter: 593
Hi
It is part of the great family of the economic units with low price chinese..not a professional product but it may be good to begin ..with prolonged use you understand the limitations of a low-price station but still ..
it is also important to check availability of spare parts in case of breakage.
I put a comparison of a professional station with a hobbyist free example
low price:
Temperature regulated: 150-500C
Adjustable air flow: up to 24 liter per minute
The 120g light weight solder iron means you can work longer without tiring.
The spring system of the compressor enables relatively untroubled and quiet operation
Transportation lock conserves the absorber of the compressor
Coated steel plated housing
Technical Specifications
Input Voltage: 230V, 50Hz
Power: 320 Watt
Tube length: ca. 1m
Dimension: ca. 160 x 148 x 240 mm, (WxHxL) control knob included, without holder
Weight: ca. 3.2 kg
professional
Power 1200W
Voltage 220V 50/60HZ
Temperature Range 100℃-500℃
Airflow Range 6-200
Max Airflow 200L/min
Size(L*D*H) 188(L)*245(D)*135(H)mm
Weight 3.65kg
Old 03-07-2017, 18:05   #13 (permalink)
Member: 2676184
Thanks Meter: 5
Finally, I bought quick 861dw.
Thanks friend ORX and the others.
It is good ORX, this product. ?
Old 03-08-2017, 07:17   #14 (permalink)
orx
Moderator
Member: 1825965
Thanks Meter: 593
Hi
if you talk for 861DW yes sure.
anyway , i don't see attachments ..
Page generated in 0.32130 seconds with 7 queries
