Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 05-26-2017, 14:43   #1 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 686
advise not to do the rehot on glued IC
Hi
Many times the rehot is a lucky solution but it does not always work
ceck image maybe useful..
The Following User Says Thank You to orx For This Useful Post:
Old 05-26-2017, 15:03   #2 (permalink)
Member: 456932
Thanks Meter: 52
then what u advise to remove glue from ic
Old 05-26-2017, 15:24   #3 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 686
for remove glue from ic personally i use 2 tool .. (depends size of ic)
- microscope
- A blade so you can see the image or the common scalpel or very fine needle syringe
When I removed the excess glue use very carefully the solder iron with flux to clean up the residues
Page generated in 0.25549 seconds with 8 queries
