Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
10-16-2006, 22:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | Battery Replacement --- how does it work Normally I see four contacts on a motorola battery +ve -ve and two leads inbetween. normally the battery voltage is 3.7 volts. When I try on some phones (motorola) by just connecting the +ve and -ve ends it does not turn on. Why is that ?. To power it, all four leads needs to be connected. What is the purpose of the other leads ? If I use a DC power supply, it will only have two leads, positive and negative. how can I use this as a substitute ? |
LOg's And Map's How Does it Work | SoftSkiner | GSM Programming & Reverse Engineering | 4 | 06-06-2002 03:33 |
Remote unlocking? How does it work? | laxxe | Wanted Products | 0 | 05-22-2001 00:19 |
Remote unlocking? How does it work? | laxxe | x1x to x45/x50 | 0 | 05-21-2001 08:56 |
how does it work ??????? | LORD_SHAH | x1x to x45/x50 | 0 | 02-04-2001 20:31 |
Motsp - how does it work | cvt | Motorola Old Legacy (EMMI) | 1 | 01-16-2001 21:05 |
