Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 04-09-2015, 20:39   #1 (permalink)
Member: 2153193
Thanks Meter: 11
Question which is the best choise, OCA or LOCA?
Hi, i want know wich technology, (oca or loca) has the best results,
and i want to know too, who can give me an advice about wich equipment buy,
thanks.
malacatonche2
Old 04-22-2015, 19:23   #2 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
well.. what is your full requirement?
Old 05-10-2015, 09:37   #3 (permalink)
Member: 357661
Oca need laminating machines and loca manual it's up to u but both need technical
Old 05-27-2015, 06:11   #4 (permalink)
Member: 1750459
Loca is cheaper to learn. oca is only optimal in large scale.
Old 05-29-2015, 22:02   #5 (permalink)
Member: 2153193
Thanks Meter: 11
i have loca, and i´m not to happy with that,, which has the better final results?
br.
Old 05-29-2015, 23:01   #6 (permalink)
Member: 1750459
OCA is cleaner, low warranty rate. Oca is very expensive to master.
Sent from my iPad using Tapatalk
Old 05-31-2015, 16:34   #7 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
br.
Why you're not happy? What's the problem/result?
The Following User Says Thank You to excessive For This Useful Post:
Old 06-12-2015, 23:42   #8 (permalink)
b2k
Member: 59737
Sonork: 100.1603188
Thanks Meter: 18
LOCA masks all imperfects of LCD
OCA give perfect factory look, no glue where it shouldn't be, you can create brand new set, but it's fully transparent, any dust, bubble it's all visible, very
Also as told before, equipment is kinda lot more expensive than UV light and to master it you need time and waste a lot of glass
Old 06-29-2015, 18:08   #9 (permalink)
Member: 2418411
OCA is best
br.
OCA is best way to refurbish LCD
1. This is very clean method little bit expensive but in this way your *******r will be satisfied
2. this is not harmful to your health
3. its very profitable because there is no complaint after done with oca
Page generated in 0.18008 seconds with 8 queries
