Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
02-17-2013, 18:26 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 254719 Status: Offline Thanks Meter: 12 | Looking for people who solder laptop chips with hot air i am looking for people who solders NVIDIA, ATI and other laptop chipsets with hot air rework stations. i am using ok industries 3500 bga rework station. (metcal) but lot of chipsets are overheated when desoldering with original lead fre solder from factory. for example: to desolder chip GF-GO7600-H-N-B1 (DV9000) 3.5cm x 3.5cm i use homemade nozzle 3.7cm x 3.7cm not to damaged motherboard, need to use profile: 260c from bottom (±180c mesured on pcb) soak from top 150sec 230c peak 180sec 360c. but on the end i hear "pop" sound and i see crack around the chipset crystal. ---------------------------------------------------------------------------------------- If i take new chipset and reball it with solder balls Sn63Pb37 then all ok, from bottom 260c, from top 230c and solder melts. i need advices. thank you all... |
