Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 05-06-2017, 22:22   #1 (permalink)
Member: 1422282
Thanks Meter: 20
Bga reballing problem
I m having **** problem while reballing chips. Problem is when ever i reball ic it gets stuck in stencile plate. N if i try to remove it then all balls gets destroy. I m really annoyed with this problem . I m using reballing paste for reballing. Anyone can suggest me what should i do?
Sent from my iPad using Tapatalk
Old 05-07-2017, 09:37   #2 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 544
Hi
1- clean well the stencil with isopropilic / propanol (important ! )
2- put the solder past on stencil On a flat surface
3- Bring in the temperature with your hot air and before removing the ICs over a bit of good flux (imortant! )
4-for removing reballed ic use hot air a max speed .
use good reballing paste ...i use Kester paste very good but expensive.
Old 05-08-2017, 21:14   #3 (permalink)
Member: 168904
Thanks Meter: 23
Hold the balls directly on the pitches of the ic
Old 05-09-2017, 00:11   #4 (permalink)
Member: 1422282
Thanks Meter: 20
You mean premade balls?
Old 05-10-2017, 17:20   #5 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 544
intends balls already ready to be positioned on Ic .. but this you can try on " big" ic as nand, on small ic for me a waste of time ..for mobile is convenient to use stencil Or you can use if you're very skills at pyramid technique with solder iron ..ceck you tube for this.
balls already ready is used for reballing m.board laptop / notebook
Old 05-10-2017, 20:11   #6 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 262
Originally Posted by orx View Post
Hi
Any trustable reseller?
Old 05-10-2017, 20:24   #7 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 544
online search Digikey .
The Following User Says Thank You to orx For This Useful Post:
Old 12-19-2017, 19:43   #8 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 760
Hi
is there any good video link of these ?
what is that above mentioned pyramid technique ?
any video ?
Old 12-25-2017, 19:54   #9 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,081
orx already replied , check youtube , there are so many videos about reballing bga ic's .
Old 12-27-2017, 07:46   #10 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 760
i have tried finding this pyramid technique with solder iron ,
but didnt get any ,
what is pyramid technique with solder iron ?
Old 12-29-2017, 09:10   #11 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 544
use the stencils and you are much faster these virtuosity for reballing with pyramid technique only serve if you have an ic with a particular design and you do not find the suitable stencil.
I bet that in a speed competition between those who use the stencils and who reball by hand I win
anyway it takes patience and practice for both.
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums.
Page generated in 0.44531 seconds with 7 queries
