Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 02-15-2017, 20:37   #1 (permalink)
Member: 2681768
Thanks Meter: 29
DC power supply ?
Hi, i can't buy a DC power supply, but i have a soldeing station with hot air with Volt/amp test
3 in 1 station.
I can use in DC power supply with this machine ? for test motherboard iphone ?
i can't post picture but i have Baku station 3 in 1 (i put on output or on "test" ?) u can see the picture on web.
Because i want to test "volt" and amp" in the motherboard for check short.
I'am newbie...
Tanks !!
Old 02-15-2017, 23:34   #2 (permalink)
Member: 168904
Thanks Meter: 23
Is you can use it, even if 1 A of current is little, if you want to power the motherboard you have to put the switch on OUTPUT and set the voltage to 4.2 V, if you put the switch on TEST measure the voltage.
Old 02-16-2017, 02:57   #3 (permalink)
Member: 2681768
Thanks Meter: 29
Ok thanks, and if i want test , i switch on test but i put volt on 0 ?
Old 02-16-2017, 15:21   #4 (permalink)
Member: 168904
Thanks Meter: 23
it does not matter because the connectors to measure the voltage are the two to the right under the word TEST
Page generated in 0.20727 seconds with 7 queries
