Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 03-13-2013, 07:57   #1 (permalink)
Member: 506354
Thanks Meter: 13
Smile Digital power supply
Sir, I am new in using Digital power supply..........so can u pls help me
how to use this in nokia,samsung,etc.to detect fault...........
Old 03-19-2013, 12:32   #2 (permalink)
Member: 1119968
Thanks Meter: 10
first post the model you have or want to buy .
a power supply is very useful , you can power up phones with it , if you have an AMPER meter on the supply you can check if a power button is working ( connect the power supply to the phone and press power , and you can see if the phone starts drawing power = power button ok ) you can test if a phone draws more current than needed (usually water damage) , find shorts in phones (connect the leads to phone ,start from 0V and raise the voltage to 500-1000mA current draw and search for a hot area ..)
and many more ...
The Following User Says Thank You to Kytan666 For This Useful Post:
Page generated in 0.12461 seconds with 8 queries
