Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 05-24-2015, 02:43   #1 (permalink)
Pratheesh T K's Avatar
Member: 866865
Sonork: 1645198
Thanks Meter: 182
EMMC AND Processors replace
Am looking for a device which can change emmc
please replay
am from india
Old 05-24-2015, 03:59   #2 (permalink)
Member: 427344
Sonork: 100.1666688
Thanks Meter: 213
u can change it manually from other phone
Old 05-24-2015, 04:18   #3 (permalink)
Member: 1988630
Sonork: 100.1684003
Thanks Meter: 312
same problem ic is pested give suggetion in ic remove and reble .which pest use to pested ic ....
Old 05-24-2015, 04:57   #4 (permalink)
Member: 1112585
Sonork: 100.1645028
Thanks Meter: 91
u can use hot air GUN with correct procedure.!
it is combination of heat & time.
time is between 2 ~ 4 minutes. heat must up gradually.
u can "calibrate" in your tools & environment.
!!!!.over heat can damages the IC or PCB.!!!!
for safety, use or put temperature sensor beneath the PCB. for heat monitor.
tips.!
check electronic component near the IC with tweezers.
to make sure that tin already been melted.
Old 05-24-2015, 07:36   #5 (permalink)
Member: 1988630
Sonork: 100.1684003
Thanks Meter: 312
ok@pai d
avaible to especial pested ic remover tool&pest
Old 05-24-2015, 16:27   #6 (permalink)
Member: 866865
Sonork: 1645198
Thanks Meter: 182
see this video this machine can do that
https://www.youtube.com/watch?v=LhtPwmx-WwM
The Following User Says Thank You to Pratheesh T K For This Useful Post:
Old 05-24-2015, 16:54   #7 (permalink)
Member: 1418143
Thanks Meter: 353
good topic ! no machine is matter but technique is the key !!
The Following User Says Thank You to psytr0nic For This Useful Post:
Old 05-25-2015, 04:23   #8 (permalink)
Member: 1988630
Sonork: 100.1684003
Thanks Meter: 312
possible to remove & reble smart phone pested ic by quick850a hot gun
Page generated in 0.18981 seconds with 8 queries
