EMMC AND Processors replace Am looking for a device which can change emmc please replay am from india |
u can change it manually from other phone |
same problem ic is pested give suggetion in ic remove and reble .which pest use to pested ic .... |
u can use hot air GUN with correct procedure.! it is combination of heat & time. time is between 2 ~ 4 minutes. heat must up gradually. u can "calibrate" in your tools & environment. !!!!.over heat can damages the IC or PCB.!!!! for safety, use or put temperature sensor beneath the PCB. for heat monitor. tips.! check electronic component near the IC with tweezers. to make sure that tin already been melted. |
ok@pai d avaible to especial pested ic remover tool&pest |
good topic ! no machine is matter but technique is the key !! |
possible to remove & reble smart phone pested ic by quick850a hot gun http://ecx.images-amazon.com/images/...UL._SX300_.jpg |
