Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
09-25-2017, 17:49 | #1 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2274262 Status: Offline Thanks Meter: 1 | General Information About mobile phone Capacitor I have some question plz : When i want to check voltage in Iphone Capacitor. I connect the battery and Turn on my phone and then use multimeter Or Only connect battery without turn on mobile phone? The battery will be fully charged or its sufficient 10-20% Charging? Its not risk to damage phone, if i check the voltage and the phone is ON?? Thanks a lot. |
09-26-2017, 01:44 | #2 (permalink) |
Freak Poster Join Date: Dec 2015 Location: Canada
Member: 2498972 Status: Offline Thanks Meter: 33 | That depends what part of the circuit you want to check. Some functions will only activate when the phone is "tunred on". As for the battery, whether it's at 20% or 100%, it will still output sufficient voltage and current for the phone to operate. Whenever a phone is powered, you always have to be careful when probing with your multimeter as you can easily cause shorts between two adjacent components. |
09-26-2017, 11:12 | #3 (permalink) |
Member: 2274262 Status: Offline Thanks Meter: 1 | Thanks a lot Minho. I have another questions plz : For example : On Iphone 6 Schemetic Capicitor c1530 , I find 25V.. My question Is : 25V its a max voltage this capicitor support? Or when i check it with multimeter (when my phone is turn on) the value will be 25 Volt? Thanks Again. |
09-26-2017, 12:29 | #4 (permalink) | |
Freak Poster Join Date: Jan 2016 Location: Hungary
Member: 2515187 Status: Offline Thanks Meter: 114 | Quote:
It means the capacitor max support 25V. | |
09-26-2017, 14:49 | #7 (permalink) |
Member: 2274262 Status: Offline Thanks Meter: 1 | Thanks a Lot.. Palle.. sorry for question.. but i m new and learing about reparing How can i know the real voltage will be.. I explain better. I have a schematic and also ZWX Dongle. Where i found this voltage before verify...?? i mean to say.. how can u know the voltage will be 15 with lcd and 4 without??? thanks |
09-26-2017, 16:42 | #9 (permalink) |
Member: 2274262 Status: Offline Thanks Meter: 1 | you are great Dude There is also very number on left and right of voltage value : like : 10 12 14 15 16 17 23 31 39 48 51 52 In the right and in the left : I64 ?? what does it mean..? |
