Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
07-18-2012, 07:10 | #1 (permalink) |
Junior Member Join Date: Jul 2012 Location: shenzhen ,china
Member: 1785847 Status: Offline Sonork: 23123361 Thanks Meter: 0 | High Power Handheld Portable Cellphone+GPS+Wi-Fi Jammer-Omnidirectional Antennas JYT-CGW100 is a multifunctional 3-in-1 jammer with a perfect integration of mobile phone jammer, GPS jammer and Wi-Fi jammer. When active, it successfully blocks GPS signals, Wi-Fi networks and all types of cellular signals (except the 3G band), with a radius for up to 20 meters (depending on signal strength). With a portable design and high power, you can go with this jammer anywhere without the worry of being tracked by GPS tracking devices. It"s very easy to operate by just pressing the ON/ OFF button on side. It comes with a rechargeable battery, an AC/DC adapter and a car cigarette charger. Specifications Technical Specifications Output power: 3.0 watt Maximum effective range: 20 meters Antenna: External,Omnidirectional Power suply: AC 110-240V, DC 12V Working temparature: ?15°C to +60°C Working humidity: 5%-80% Jamming System Analog: NMT,TACS,AMPS Digital: GSM,CDMA,DCS,PHS,PDC,PCS,GPS L1 GPS: GPS L1 1575.42 MHz 2.4G: Bluetooth, Wifi Jamming Frequencies (American Version) 850-960 MHz: GSM 850, GSM 900, CDMA, CDMA 800, iDEN, TDMA, AMPS 1805-1990 MHz: GSM, GSM1800, GSM 1900, CDMA 1900,PHS, PCS, NEXTEL 1575.42 MHz: GPS L1 2400-2500 MHz: Wifi, Bluetooth Jamming Frequencies (European Version) 925-960 MHz: GSM 900 1805-1880 MHz: DCS,GSM 1800 1575.42 MHz: GPS L1 2400-2500 MHz: Wifi, Bluetooth Physical Specifications Product size: 108x63x33 mm Product weight: 330 g Package size: 280x145x75 mm Package weight: 652 g Battery Type: Lithium-Ion Capacity: 1800 mAh Charging time: 3 hours Working time: 1.5 hours Package Contents AC/DC adapter: 1 unit Car adapter: 1 unit Last edited by THE CLASH; 07-18-2012 at 09:55. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Transmitter output power | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-17-2001 23:02 |
8810 power off | Fahlstrom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-08-2001 13:59 |
need advice on 8810 headset/power down problem | goof | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-24-2001 20:56 |
blue Display in Nokia Cellphones | TheDon | Nokia Hardware & Hardware Repair | 0 | 10-29-1999 18:28 |
