Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 09-14-2018, 20:25   #1 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
high power soldering iron
hello
a question , who uses a 120 / 150w high power solder iron to remove the ic? example, iphone 7 audio ic, iphone 6s pmic ..etc
Share the experience ..
Old 09-18-2018, 01:29   #2 (permalink)
Member: 861495
Thanks Meter: 52
bro could explain a little do you mean by haveing solder on the end a nd lifting it straight from on top of a ic I seen a youtuber do that with a knife edge tip and a blob of solder
Old 09-20-2018, 12:54   #3 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
yes of course maybe with a more controlled and less empirical system .. check the example , this about a U2 on iphone 5 but same tecnique is applicable to big ic as pmic in critical area or others ic.
the purpose is not to overheat / damage other components in fact there are some tips for iron for this purpose
The Following User Says Thank You to orx For This Useful Post:
Old 09-20-2018, 18:43   #4 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
yes I do bro but I use 75w soldering iron from soldron , here local made company.
you also need very steady hand to do this , and yes it's very usefull for critical areas .
Old 09-20-2018, 19:38   #5 (permalink)
Member: 861495
Thanks Meter: 52
very interesting Ive been thinking about buying a jbc station i have original hakko and was gonna buy a chinese jbc station knock off you think its worth it ?I might just risk it to find out
Old 09-20-2018, 20:34   #6 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
hi Sarcar , 75w is a low power for big ic infact my test is done on my solder iron with same power but the result is not good .
I've ordered a new station QU**K ts1200a 120w the next test i give here confirmation if it work.
@Rasec
hi , I have seen these Knokoo clones jbc but they are still expensive and certainly of quality but for this specific use I would spend less for a 120 / 150w Quick or clone that is..
The Following 2 Users Say Thank You to orx For This Useful Post:
Page generated in 0.16487 seconds with 9 queries
