Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 04-23-2017, 13:18   #1 (permalink)
Member: 1422282
Thanks Meter: 21
Hot tweezer for iphon backlight filters?
Anyone recommend cheap hot tweezer for iphone backlight filter replacment?
Sent from my iPad using Tapatalk
Old 04-25-2017, 10:03   #2 (permalink)
orx
Moderator
Member: 1825965
Thanks Meter: 596
hi
i not recommend you this tool because is not simple to use for components lile Fl , caps , resistor with size 0802, 0603 , 01002 on iphone 6 or others m.board , 5S / 5 , etc..
Tweezers are too big for be handle, only some expensive (very) soldering brands can to be useful for this like , weller , original Hakko , Jovy ..For the best and economic way i advice common soldering iron with 0,1 /0,2 tip . put the component on tip and place the component helper to place it with a tweezer .
The Following 2 Users Say Thank You to orx For This Useful Post:
Old 04-28-2017, 22:42   #3 (permalink)
Member: 168904
Thanks Meter: 23
Or you can use tin paste that makes welding simpler
The Following User Says Thank You to fulviospano For This Useful Post:
Old 05-10-2017, 15:53   #4 (permalink)
porn's Avatar
Member: 134206
Thanks Meter: 15
yes tin paste easy way to fix filters
The Following User Says Thank You to porn For This Useful Post:
Old 10-20-2017, 10:58   #5 (permalink)
Member: 777576
Thanks Meter: 27
which tin paste do you guys use? can you recommend any?
Old 10-20-2017, 14:34   #6 (permalink)
orx
Moderator
Member: 1825965
Thanks Meter: 596
I advice for Kester R286 but is expensive in alternative to low cost , Mechanic (made in china)..
anyway there is a quality difference .
The Following User Says Thank You to orx For This Useful Post:
Page generated in 0.26399 seconds with 8 queries
