Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
02-12-2006, 22:14 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: T.E.T.O.U.A.N
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | How to make battery calibration ..? recalibrate battery on C/M/S35 (i got this method from Gazbag): what you only need are a digital voltmeter and Siemens Sensor Tool v1.3 ... Step-1: discharge battery to empty -> put in the phone (do not turn ON) -> measure battery voltage with VOLTMETER -> write the number you got (in milivolts) as VBatt2 Step-2: Run Siemens Sensor Tool -> look at SENSORS: VBattDSP -> write the number you got as VBattDSP2 Step-3: charge battery to full -> put in the phone (do not turn it ON) -> measure battery voltage with VOLTMETER -> write the number you got (in milivolts) as VBatt1 Step-4: Run Siemens Sensor Tool -> look at SENSORS: VBattDSP -> write the number you got as VBattDSP1 Step-5: Write those values you got from step 1-4 in the Siemens Sensor Tool's calculator (on right side) -> click "Calculate SpgY03V SpgY04V" button -> then you will get the right parameters Step-6: Write it to your phone ... Siemens Sensor Tool..? it-s same for Nokia and others Phone and when can i get it (Siemens Sensor Tool)..?? |
The Following User Says Thank You to Tetouan Gsm For This Useful Post: |
Guid me please how to make a china phone battery | mobilecitycbk | Chinese Models & Cloned Phones | 5 | 06-11-2010 04:10 |
how to screen touch calibration operation | turkcellgsm | VE-KING | 2 | 02-02-2009 10:32 |
how to skip touchscreen calibration in c2000 | sayedhas | SpiderMan | 5 | 08-10-2008 03:54 |
I need link to learn How to Make A Gsm Soft /unlock | dr.motorola | GSM Mobile Links | 2 | 11-30-2001 12:22 |
how to make a ic2 bus cable and how to use? | alro | Hardware Repair by brands | 4 | 06-20-2001 11:22 |
