Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
02-06-2006, 13:34 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Brazil Age: 44
Member: 77651 Status: Offline Thanks Meter: 21 | Howto write a PIC using IC-PROG I'm a newbie writing PICs... I'm trying to write a PIC (12F629) using IC-PROG on Win98, but when I try to check the HEX file I get a eror 000F and when I try to write the file the PIC's value is only '0000...'. Any idea?! Is a problem with the HEX file or there is some kind of configurantion to do on IC-PROG??? Tnx. |
02-07-2006, 10:33 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | this will help friend thnks reply if not work http://www.semis.demon.co.uk/Pics/PICmain.htm |
02-08-2006, 04:30 | #3 (permalink) |
No Life Poster Join Date: May 2002 Location: Wolverhampton UK Age: 54
Member: 12296 Status: Offline Thanks Meter: 9 | The ICSP based programing works fine with IC prog..There are a few schemes for that...I think the problem is with your hex may be the hex is not in the right format...which hex you are tying to write..? Contact me in any IM i'll try to help... WBR Surej |
02-09-2006, 11:35 | #4 (permalink) | |
No Life Poster Join Date: May 2005 Location: Romania Focsani
Member: 149135 Status: Offline Thanks Meter: 234 | Quote:
1-You try to reprogram original pic from SCDR clone V5?? Or is a new Blank Pic? Bcz if you want to program old pic is next problem..pic vas programed before whit CP(code protect) and when you program a new hex..when the ICprog whant to veryfy get error bcz canot read content(is protected)! And for this reson you get Failed at adres h00..bcz cannot read content of pic (is whit code protect) Try to read content of PIC And you will see only 0000....but in last line i think 3F8 you will see something...this is oscilator calibrated value..you must restore after program PIC!! So my opinion is you need a PIC new blank..and a good Hardware for ICprog who is offer 13V for MCLR pin(pin4....in this pin you need 13 V for programming PIC)!! Good Luck and send result!! | |
The Following User Says Thank You to djdansmart For This Useful Post: |
02-09-2006, 11:48 | #5 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Romania Age: 42
Member: 81232 Status: Offline Thanks Meter: 196 | For programing first u must erase it and after u hawe to write content to it . U must check config so it wil work , if u don't chose good config then will never vork. |
02-23-2009, 11:43 | #7 (permalink) |
Junior Member Join Date: Feb 2009
Member: 979095 Status: Offline Sonork: seshug22 Thanks Meter: 0 | ic programming I m a new in PIC programming when i programming the HEX file to PIC 16x458 through programme it show error occured at 000f, when i read it shows 0000 to all memory locations plz give me suggessions and setting for doing programming thank you |
02-23-2009, 11:48 | #8 (permalink) | |
Member: 979095 Status: Offline Sonork: seshug22 Thanks Meter: 0 | Quote:
thank uou | |
03-02-2009, 03:35 | #10 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Quote:
BR. | |
03-04-2010, 22:23 | #14 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: !!!! AWAY FROM BOARD, STUDY !!
Member: 1055354 Status: Offline Thanks Meter: 252 | Quote:
(old and new) is the original PICSTART Plus by Microchip that can work directly from MPLAB. Also ICPROG and similar crappy cheap designs are not very reliable - especially with OTP/EPROM based PICs who require good power supply for VPP. Bad voltage VPP can result in non or partially non-working PIC or bits toggling after some months/years and if VPP is rised too slow by cheap programmers, PIC's program counter will increment before setting to programming mode and result of this is badly programmed PIC. If OTP => put to trash. Newer Flash-based PICs generate their VPP internally and just require VPP for setting into programming mode, therefore they work better with cheap designs. | |
03-04-2010, 22:30 | #15 (permalink) |
Member: 1055354 Status: Offline Thanks Meter: 252 | A very good USB programmer for Flash-based PICs can be found here: http://www.sprut.de/electronic/pic/p.../index.htm#b8p I use this myself almost more often than my PICstart when i develop code and only use the PICstart to program some old leftover OTP/EPROM PICs. |
howto write in bb5 flash? | tekit.dk | Nokia Base Band 5 ( BB-5 ) | 1 | 03-23-2006 20:47 |
What programmer to buy to use with IC-Prog? | gary stonecutte | Sim Cloning and Scaning | 2 | 09-24-2004 18:30 |
Why I can't use IC-prog on WinXP? | sir_wo | Sim Cloning and Scaning | 2 | 07-07-2004 07:52 |
IC-PROG doesn't write to silver card | virtualj | Sim Cloning and Scaning | 10 | 07-25-2003 18:33 |
ic prog | alrm7 | Sim Cloning and Scaning | 1 | 09-08-2002 03:50 |
