Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
11-02-2010, 08:13 | #1 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1433168 Status: Offline Thanks Meter: 0 | Use Hot Air Gun / ****er for Removal of SMD IC’s without damaging the ICs and the Bo We represent STEINEL from Germany for their Hot Air Heat Guns useful for various applications. Microprocessor-controlled, high-end heat gun with temperature control, LCD display and cold air stage for Removal of SMD IC’s & PTH Componets / Microprocessors of Mini Systems, Mobile Phones, CTV, LCD TV, or any other electronic Chassis is difficult using our Normal Soldering Irons. Hot Air Gun is useful to facilitate easy rework without damaging the ICs and the Boards. Apart from above there many other applications like: 1. Removal of SMD Components and Dualin IC's through Printed Through Hole Circuits (which otherwise would be difficult without the expensive De-soldering Stations, SMD Rework Stations). 2. Removal of small particles that get stuck in the small holes, while removing Dualin IC's through Printed through hole Circuits. 3. Removal of SMD IC's specially Micro Processor for System etc. 4. Removal of moisture on the PCB's can also be done with the Steinel Hot Air Gun. 5. Shrink Sleeving and Shrink Tubing. 6. Softening of Wires in Motors during repairs. 7. Drying of Adhesives / Filters / Activating Emulsions etc. 8. Several other applications where flameless heat is required. Applications in Refrigerators / Washing Machines / Air-conditions 1. Alignment of Gaskets in the Refrigerators. 2. To Smoothen the Doors of the Refrigerators. 3. To Remove White Marks in HIP **** Moulded Sheets. 4. To Remove Moisture. 5. For drying of metallic parts after washing in water jet For more details please write to us and we will be happy to assist you. Board: 022-26731904 / 26731052 Ext # 35 Fax: 022-26731901 Email: [email protected] Web: Occupancy Sensors, Motion Sensors, PIR Sensors, Lighting Automation, steinel presence sensors, HID Dimming, Hot Air Guns, heat guns, Glue Guns, Automated External Defibrillators, AED and Drugs of Abuse Test Kits, surgical blades, audio video door pho Web: Heat gun, hot air gun, heat torch, industrial hot air guns and ****ers for heat shrink applications in India by Pammvi Web: http://www.hotairgun-heatguns.com/ Last edited by pammvi; 11-02-2010 at 08:14. Reason: add one more website |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
