Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 12-18-2018, 06:03   #1 (permalink)
Member: 861495
Thanks Meter: 38
JC PRO 1000S Tutorial, how to, tips and tricks
JC PRO 1000s is the interface and you can add many modules
32/64 NAND hard disk read/write module
Support iPhone 4 4S 5 5S 5C 6 6P
Support iPad 234 Air 12 Mini 1234
JC P7 PCIE NAND read/write module
Support 6S 6SP 7 7P 5SE
Support iPad Pro
Feature:
· touch screen
· Free ROTS Operating system
· Support SD USB Communication
· Support Chinese and English
· Direct online, offline
· Support APP download
-most be powered with usb c mine didnt not come with internal battery
-adaptor for Ipad2,3,4 only works with wifi versions Ipad 2 only works newer revision of ipad 2
-adaptor for ipad 456 works with wifi versions of ipad 4, air1 and air2
will add more information when modules arrive
Old 05-31-2019, 18:46   #2 (permalink)
Member: 2907377
Thanks Meter: 2
I have the P7 and the 456 Air 1/Air 2 adapter and both of them are total garbage. The P7 can't read or write to at least half of the nands I've thrown at it. The online software is full of bugs, the ipad 456 adapter can't read or write to any devices over 64gb, the build quality of the 456 adapter is horrible, the springs on mine broke within the first week, and I also have the jc pro 1000s and it has so many issues I can't even count them.
Anyone thinking of buying a programmer should read as much as possible before getting invested. The JC line of modules is very appealing but if the other units are anyuthing like the junk I received I'd rarther spend the money elsewhere,
Old 05-31-2019, 21:46   #3 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 793
too me i've Jc host pro1000 and family , about the adapter 456 (nand in lga standard) not support the damned Toshiba Nand 32-64 but anyway i've solve on ipad air 1 and 2 serial with 128 gb nand , 16gb (toshiba) and 64gb (sandisk) but always formatting and rewriting the partitions contrary to their procedure which seems easy...
About Toshiba nand these nand are not supported also from other programmer and the bad thing is that they are present on a good 70 percent of the iPad air and air 2 so if JC made an effort to update their software to write these toshiba would be perfect but instead like many manufacturers of similar tools develop an exceptional tool and then leave it and focus on others ..
I've also NandPro and seems to support these Toshiba with adapter but this item seems unobtainable in the market so need to remove the nand.
You've right bad support with the software while some their tool are good.
Old 06-01-2019, 22:51   #4 (permalink)
Member: 861495
Thanks Meter: 38
I have also the nand pro but what tool do you mean the isp conector ? if so i just bought it from gsmserver yesterday
Old 06-03-2019, 10:12   #5 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 793
ckeck here ..
Old 06-03-2019, 18:34   #6 (permalink)
Member: 861495
Thanks Meter: 38
both are avaiable for sale on gsm**er bought a few days ago
Old 09-09-2019, 15:03   #7 (permalink)
Member: 71290
Sonork: 100.1645657
Thanks Meter: 99
Hello
query.
I have the JC 1000S and from one day to another I stop working,
Now the software only recognizes me the USB port and does not read me any NAND, nor does it turn on any of the identification lights, blue, green or red
Please someone help me.
attached error photo
Thank you
help please
Can anybody help me.
It is not driver problems, everything is OK in the installation.
I think the internal memory that allows reading the NAND memories was deleted
Old 09-12-2019, 20:31   #8 (permalink)
Member: 1744018
Thanks Meter: 11
Hi,
install :assistant 1.1.99.17
Old 09-12-2019, 21:24   #9 (permalink)
Member: 1744018
Thanks Meter: 11
Old 09-12-2019, 21:35   #10 (permalink)
Member: 1744018
Thanks Meter: 11
Old 09-12-2019, 23:04   #11 (permalink)
Member: 1744018
Thanks Meter: 11
HI,
Photos above are about jc-P7 plug in computer and running with the firmware
Old Today, 00:12   #12 (permalink)
Member: 2911332
JC Software for PC looks like some 9yo with no skill is writing it. They'd be better off to hire a high-school intern to fix the obvious issues. Totally ridiculous.
Page generated in 0.20987 seconds with 8 queries
