Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
01-16-2020, 12:20 | #1 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 934255 Status: Offline Thanks Meter: 63 | Solder doesn't stick on usb conector why? Same micro usb charge conector the solder glue perfectly... in other the solder doesn,t stick.. anone already have the same problem? Already change iron, plut flux, temperature etc.. i think maybe is the quality of the metal on same usb charge conector... Iron is beetween 300 and 450 degrees.. but is not iron problem because some conector the solder stuck easily.. any way to pass this problem? tanks |
01-17-2020, 08:16 | #3 (permalink) | |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | Quote:
before of to solder any connectors whatever its nature you should always clean tin residues with braid this facilitates the cohesion of the tin . Remember good flux good tin temperature on iron stable to 350° i advice to use copper tips are economic and great performance. | |
The Following User Says Thank You to orx For This Useful Post: |
