Max 3232 in old universal box i have old universal box based whit Max 232 can i change just Max 232 whit Max 3232 or i nned other change in the box, if yes please shemas for univirsal box whit Max 3232 thanks for all replay |
you may change MAX232 to MAX3232 but you must change supply from 5V to 3V because MAX3232 is 3V IC |
how to make shematic please |
Wrong !! 3232 can be powered between 3,6 and 5v !!! replace 232 with 3232 and change also pump capacitors to 0,1uF. If you supply 3232 with 5v, your peak on tx will be 3,6v, if you supply with 3,6 peak will be 3 V. |
i change just 10uF capacitors to o,1uF? or all pump capacitors 10uF(4ps) + 47uF(1p) + 470uF(1p) ? big thanks for replay |
replace just 10uF capacitors with 0,1uF. |
