Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
05-08-2005, 20:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: www.sevgigsm.net Erkan Yasar Age: 61
Member: 81576 Status: Offline Thanks Meter: 2,128 | power suply what can we do wıth the modıfıed power supply? u can start the dct-3 phones wıthout batterıes and upgrade software. u can fınd the ıc whıch makes problem at the phone. u can decıde to upgrade sofware or tecnıcal move. dct4 phones u can start the phone wıthout battery and fınd the problem. u can reach wonderfull results at sıemens phones. u can upgrade software and fınd the ıc whıch makes problem wıthout usıng battery. at samsung phones u can fınd a solutıon at the early fınıshed batterıes. u can fınd a result at the chargıng problems and start all samsungs wıthout battery usebılıty at all phones %100 wıth a package ıncludes dct3, dct4 cable shemas and a cd ıncludes ınformatıon repaırın by |
The Following User Says Thank You to sevgigsm For This Useful Post: |
05-10-2005, 18:51 | #4 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 17330 Status: Offline Thanks Meter: 15 | Are you saying you can repair phones without test jigs? What is the current and voltage ratings of this power supply? I think some of the descriptions are misleading... just like put fuel in the car and it should drive itself! |
05-11-2005, 06:52 | #5 (permalink) | |
Crazy Poster Join Date: May 2005 Location: Ankara Age: 44
Member: 142634 Status: Offline Thanks Meter: 0 | Quote:
05-12-2005, 15:55 | #6 (permalink) |
Junior Member Join Date: Feb 2005 Location: istanbul Age: 42
Member: 119166 Status: Offline Thanks Meter: 54 | satndard power supplies can't do their jobs like ours. We changed eeprom which is inside the unit. So we can find problems w1th check1ng voltage ratings. To spectrum: u should buy one to have the rating. |
05-12-2005, 18:24 | #7 (permalink) | |
Member: 17330 Status: Offline Thanks Meter: 15 | Quote:
Are you saying I need to buy first before I know the specs? You must be joking! Give me the technical specifications and I will compere it with other ps in the market, then I may decide to buy yours Thx | |
05-14-2005, 13:07 | #8 (permalink) |
Member: 119166 Status: Offline Thanks Meter: 54 | this a standart power supply with a modified eeprom. we take the eeprom ic and upgrade its software by using technical equipment. i can give a value for you for an example. if the supply shows the current is 0.001 that means the upp is dead. so u can solve the problem by changing the upp. We have two kind of power supply 1_ Analog Power Supply = 150 USD 2_ Digital Power Supply = 250 USD |
05-30-2005, 16:33 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2005 Location: London Age: 47
Member: 148419 Status: Offline Sonork: 100.999999 Thanks Meter: 54 | Power Supply is useful in these cases If a phone is dead and water demaged or short circuit using with the power supply will not demage the battery and will be clearly shown on the meter so u can findout that there is short circuiting in phone or not If there is short circuiting maximum current will flow other wise normal rating will be showed on meter Thanks |
nokia 7610 0.06 amp when connect to power suply whit out switch on | morteza-icu | Nokia Hardware & Hardware Repair | 0 | 06-19-2006 12:33 |
old vcr power suply! | sergioems | Off Topic Zone | 0 | 11-22-2005 18:00 |
perfect tool Power suply | sevgigsm | Nokia Hardware & Hardware Repair | 1 | 03-26-2005 23:21 |
How to get constant power suply from C55 ??? | mitpommes | E-Gold Based Phones | 0 | 12-10-2003 18:27 |
i need a alcatel db BE cable schematic with external power suply | guiso | Alcatel & TCL Old Models | 2 | 08-25-2001 13:13 |
