Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
09-28-2004, 19:11 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | manual of oscilloscope 20 mhz curious to know how it work, but nobody could explain it here some page for viewing how an oscilloscope work would be really appreciated more gladly if there's someone who could describe how to use it in gsm mobile repairing Ps : also get rf counter 1 Ghz with 10 mhz output and 2.4 Ghz with 13 mhz output, someone advise that this device must be used with the oscilloscope in gsm mobile repairing, is it true ? thanks |
09-29-2004, 20:38 | #2 (permalink) |
Insane Poster Join Date: Sep 2003 Location: UK Age: 70
Member: 38731 Status: Offline Thanks Meter: 0 | The screen of a scope is covered with vertical and horizontal lines for easy measurement. This is called the Gratiscule A dot of light takes time to go horizontally from point A to B this is the timebase. The faster it goes thedot of light leaves a trail and eventually a line called a TRACE. Vertical adjustment is the measure of voltage per box section so if a trace was inthe middle and you put 1 volt input and the vertical is set at 1volt per division it will jump one box line. Timebase X Voltage in equals frequency Paul |
02-10-2005, 06:24 | #8 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: Malaysia Age: 40
Member: 52755 Status: Offline Thanks Meter: 10 | Quote:
11-06-2005, 11:07 | #11 (permalink) | |
pls any body post or give link of level3 service manual of 6085 | digitized | Nokia Hardware & Hardware Repair | 2 | 02-27-2009 22:45 |
requiring video manual of IMEI patch of all bd | aminnovelty | Universalbox | 1 | 09-15-2008 09:24 |
What type of oscilloscope is needed for gsm repair? | max8108 | Hardware Repair by brands | 6 | 07-31-2002 06:46 |
doubts on dejan pic ics..otp or jw 4Mhz or 20 Mhz | sidharthaharish | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-15-2002 10:01 |
URGENT NEED OF 3310 20-30 FLASH | jazz131 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-09-2001 06:41 |
