Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 01-20-2018, 14:00   #31 (permalink)
Member: 2229936
so I solved the problem
Old 01-22-2018, 18:30   #32 (permalink)
Member: 468346
Thanks Meter: 4
Stuck updating
How to solved pls rply
Thnks
Old 01-27-2018, 18:07   #33 (permalink)
Member: 604209
Thanks Meter: 2
stuck on install
hi . how to solve this problem.
thanks
Old 01-29-2018, 19:48   #34 (permalink)
Member: 468346
Thanks Meter: 4
Stuck updating
Pls how to solve stuck in install any one Rply
The Following User Says Thank You to riyazsmarty For This Useful Post:
Old 02-01-2018, 12:24   #35 (permalink)
Member: 604209
Thanks Meter: 2
hi how to solve this stuck in install?
Old 02-05-2018, 14:56   #36 (permalink)
Member: 604209
Thanks Meter: 2
naviplus pro 3000s
i have solved my problem with v1.1302 first write boot than new version
Old 02-05-2018, 15:10   #37 (permalink)
Registered User
Member: 252045
Thanks Meter: 7
Were you found that version for download?
The Following User Says Thank You to telecelula For This Useful Post:
Old 02-05-2018, 18:22   #38 (permalink)
Member: 2595542
Thanks Meter: 2
plz the software ......................
Old 02-05-2018, 22:49   #39 (permalink)
Member: 57475
Thanks Meter: 3
You mean v1.1301?
Gesendet von meinem KFHDX mit Tapatalk
Old 02-09-2018, 09:37   #40 (permalink)
Member: 95409
Sonork: 100.1623134
Thanks Meter: 20
Naviplus Pro3000s v1.1302 update and start install error solution
https://drive.google.com/open?id=1oc...o1tbN_df0TxDNN
thnks for update file and everything
https://www.vipprogrammer.com/
The Following User Says Thank You to digitek For This Useful Post:
Old 02-10-2018, 10:36   #41 (permalink)
Member: 1668596
yes. i fix it too. I mean the stuck in install mode. I flash it with this version
naviplus-pro3000s-v1-1302-update
check it is link in the forum
Old 02-10-2018, 14:08   #42 (permalink)
Crazy Poster
Member: 2601523
Thanks Meter: 19
more pro3000s adapter and user manual, pls check:
https://www.vipprogrammer.com/news/u...-post-680.html
The Following User Says Thank You to vipprog For This Useful Post:
Old 02-10-2018, 14:09   #43 (permalink)
Crazy Poster
Member: 2601523
Thanks Meter: 19
http://forum.gsmhosting.com/vbb/f38/...ution-2341691/
Old 02-21-2018, 05:53   #44 (permalink)
Member: 2798773
Can the naviplus handle a air 2 or iPad pro thanks in advance
Old 02-25-2018, 07:45   #45 (permalink)
Member: 1710813
Sonork: gsmhosting.com
Thanks Meter: 38
v1.1302
Page generated in 0.21935 seconds with 9 queries
