Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Unread 02-10-2018, 13:09   #46 (permalink)
Crazy Poster
Member: 2601523
Thanks Meter: 14
Naviplus Pro3000s v1.1302 update and start install error solution
Unread 02-21-2018, 04:53   #47 (permalink)
Member: 2798773
Can the naviplus handle a air 2 or iPad pro thanks in advance
Unread 02-25-2018, 06:45   #48 (permalink)
Member: 1710813
Thanks Meter: 34
v1.1302
Unread 02-28-2018, 11:34   #49 (permalink)
Member: 1988922
naviplus go blink after loading solution please
Unread 03-13-2018, 07:51   #50 (permalink)
Crazy Poster
Member: 2601523
Thanks Meter: 14
repair Naviplus pro3000 - guide -
remove adapter, or update the machine by new bin file
Unread 05-04-2018, 23:36   #51 (permalink)
Member: 2493845
Sonork: celular. [email protected]
naviplus 3000
friend we need urgent solution we are reseller of your product your update disabled your equipment leaving blocked on start install please help us
Unread 05-08-2018, 23:42   #52 (permalink)
Member: 792851
Thanks Meter: 30
Originally Posted by abbassat1974 View Post
v1.1302
Hi yes i have same problem after update with V1.1302 mass write mode disable how to active this,now when i change new hdd to update to 16 gb to 128gb phone can not active even we write correct info we need solutions plz
Unread 05-13-2018, 00:21   #53 (permalink)
Member: 388862
Thanks Meter: 45
Originally Posted by [email protected] View Post
Hello to all friends ...
There is a tutorial which explains step by step using this programmer for NAND?
PRO3000 _1.1302
ok?
https://pan.baidu.com/s/1wAvklhcD4Wf7XYLwAAdX0A
p2s3
Unread 05-13-2018, 23:21   #54 (permalink)
Member: 792851
Thanks Meter: 30
Originally Posted by lihua View Post
this is not guide its file to update naviplus he want full guide for naviplus
i can not find proper guide as well
i m having issue i have 3 divise good working device need to change 16gb to 128gb when i do that after restoring it saying phone can not active,but when i put back old 16gb hdd works,so i dont know why i think naviplus new version do not copy data proper,if someone has proper guide plz share here
Unread 05-19-2018, 06:24   #55 (permalink)
Member: 1417534
Thanks Meter: 3
I THOUGHT they did that for the reason below
v1.1301 and v1.1303 disable the 'mass write mode' in configer interface.if enable the mode,when write NAND second time with the same FW,it will modify the last 2 byte of WIFI MAC automatic and when restore,it can't be active.
Unread 05-19-2018, 06:26   #56 (permalink)
Member: 1417534
Thanks Meter: 3
i mean version 1.1301 and 1.1302
Unread 05-19-2018, 06:30   #57 (permalink)
Member: 1417534
Thanks Meter: 3
i thaught the did it for this reason below.
v1.1301 and v1.1302 disable the 'mass write mode' in configer interface.if enable the mode,when write NAND second time with the same FW,it will modify the last 2 byte of WIFI MAC automatic and when restore,it can't be active.
Unread 05-20-2018, 23:33   #58 (permalink)
Member: 792851
Thanks Meter: 30
so what to do? i have same issue i m writing 16gb hdd to 64gb hdd but can not active how can we fix wifi mac last 2 word dont get change?
Page generated in 0.18534 seconds with 7 queries
