Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
03-25-2018, 22:08 | #48 (permalink) | |
Freak Poster Join Date: Jan 2013 Location: socal
Member: 1866487 Status: Offline Thanks Meter: 113 | Quote:
05-04-2018, 23:36 | #52 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2493845 Status: Offline Sonork: celular. express@outlook. Thanks Meter: 0 | naviplus 3000 friend we need urgent solution we are reseller of your product your update disabled your equipment leaving blocked on start install please help us Last edited by cardozo123; 05-04-2018 at 23:42. |
05-13-2018, 00:21 | #55 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | Quote:
ok? https://pan.baidu.com/s/1wAvklhcD4Wf7XYLwAAdX0A p2s3 | |
05-13-2018, 23:21 | #56 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | Quote: i can not find proper guide as well i m having issue i have 3 divise good working device need to change 16gb to 128gb when i do that after restoring it saying phone can not active,but when i put back old 16gb hdd works,so i dont know why i think naviplus new version do not copy data proper,if someone has proper guide plz share here | |
05-19-2018, 06:24 | #57 (permalink) |
Crazy Poster Join Date: Oct 2010
Member: 1417534 Status: Offline Thanks Meter: 4 | I THOUGHT they did that for the reason below v1.1301 and v1.1303 disable the 'mass write mode' in configer interface.if enable the mode,when write NAND second time with the same FW,it will modify the last 2 byte of WIFI MAC automatic and when restore,it can't be active. |
05-19-2018, 06:30 | #59 (permalink) |
Member: 1417534 Status: Offline Thanks Meter: 4 | i thaught the did it for this reason below. v1.1301 and v1.1302 disable the 'mass write mode' in configer interface.if enable the mode,when write NAND second time with the same FW,it will modify the last 2 byte of WIFI MAC automatic and when restore,it can't be active. |
05-20-2018, 23:33 | #60 (permalink) | |
