Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 09-24-2018, 22:22   #91 (permalink)
Member: 231078
Thanks Meter: 17
v1.1307
In this update they removed the option to repair the errors 9 21 4013
Old 09-26-2018, 05:59   #92 (permalink)
Member: 1961681
Pro300s 1.1307 update feature losted
Pro3000s 1.1307 update they removed the feature for fix itunes error 9, 4013,4014..
Do you have new update??? Have any solution for fix that???
Old 09-26-2018, 06:12   #93 (permalink)
Member: 138423
Sonork: 75171702
Thanks Meter: 12
Can update to 1.1306 and work againg Fix error 9, 4013, 4014
The Following User Says Thank You to henrynicolas For This Useful Post:
Old 09-27-2018, 22:46   #94 (permalink)
bobo bokota's Avatar
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 494
Sorry who can help me with naviplus to fix error 9 and 4013 because I remove the Nand I program and I reball but be error 4014
I really in need because I can not solve the problems on the iPhone. Someone can guide me through the steps to repair or read etc I even search forums on the Web but I have not found
Envoyé de mon SM-G900H en utilisant Tapatalk
Old 09-28-2018, 20:45   #95 (permalink)
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 494
Hi guys I have an IPhone 6 more after restoration it gives error 4013 I removed the Nand then I program with naviplus I try to restore again it gives error 40 that it can create that or that I must do thank you any advice will be received with admiration
Old 10-03-2018, 16:34   #96 (permalink)
Member: 1961681
update 1.1306
can you give the new link for update 1.1306??
The Following User Says Thank You to ameersharedmkd For This Useful Post:
Old 10-04-2018, 11:18   #97 (permalink)
Member: 2380571
Thanks Meter: 2
Version 1307
Anyone got a fix to the 1307 firmware that is required to use the iTunes error 9 etc
The Following User Says Thank You to pc-dept For This Useful Post:
Old 10-05-2018, 08:45   #98 (permalink)
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 494
Downgrade firmware for repair
Envoyé de mon iPad en utilisant Tapatalk
Old 10-05-2018, 12:04   #99 (permalink)
Digital EDGE's Avatar
Member: 1240161
Thanks Meter: 159
Just updated to v1.1305
Now it keeps on restarting
Is there any solution?
Old 10-09-2018, 15:18   #100 (permalink)
Member: 2813930
Thanks Meter: 9
Smile Naviplus Update 1308
The solution is to upgrade the firmware to version 1308 to restore HDD FIX function
Old 10-09-2018, 17:07   #101 (permalink)
Member: 2870809
link update 1.1308
1.1308 could you pass me the update link
Old 10-09-2018, 18:11   #102 (permalink)
Member: 2813930
Thanks Meter: 9
Version 1307 does not accept downgrade. Until you restore to version 1307, Naviplus will not initialize
Old 10-09-2018, 18:23   #103 (permalink)
Member: 2813930
Thanks Meter: 9
I can not post links as long as I do not have more than 10 posts published here. I will do this to share with you.
Old 10-09-2018, 18:38   #104 (permalink)
Member: 2870809
could you send me in my email? please I'm without the HDD FIX
Old 10-09-2018, 19:43   #105 (permalink)
Member: 2813930
Thanks Meter: 9
Yes of course! What is your email?
Page generated in 0.28817 seconds with 9 queries
