Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 12-14-2018, 08:40   #136 (permalink)
J_M
Member: 516470
Thanks Meter: 70
Originally Posted by alsaber View Post
i have, ipad 2, need changue serie but always this error, any idea , i update box firmware more new but same error.
can help
thanks
Need to replace with supported NAND type
The Following 2 Users Say Thank You to J_M For This Useful Post:
Old 12-16-2018, 05:44   #137 (permalink)
Member: 2287795
Thanks Meter: 2
Use Toshiba or Hynix, in this model only
The Following User Says Thank You to hacker1handsome For This Useful Post:
Old 12-17-2018, 18:55   #138 (permalink)
Member: 1360333
Thanks Meter: 5
hello please i cant activate ipad 4 wifi after changing S/N. i gives error activating, contact support.
The Following User Says Thank You to godwin25 For This Useful Post:
Old 12-17-2018, 19:17   #139 (permalink)
Member: 1360333
Thanks Meter: 5
i ahve two ipad 4 wifi all cant activate after changing the serial number with pro3000s. please any solution?
Old 12-27-2018, 00:45   #140 (permalink)
Member: 2172121
Thanks Meter: 2
Hi how to remove icloud on ipad pro and ipad mini 4
Old 12-30-2018, 08:50   #141 (permalink)
FULL_ERASE's Avatar
Member: 1574276
Thanks Meter: 37
Navipluspro3000s
Just new for this repair tool
Anyone can tell me what is the latest version of this tool now?
regard's
Old 01-13-2019, 15:35   #142 (permalink)
Member: 2219780
Sonork: 100.1662738
Thanks Meter: 52
regard's
V1.1308
https://mega.nz/#!ZNNmCCzS!DpNRQuy9x...kigHxSXmbLnRl4
Old 01-17-2019, 06:20   #143 (permalink)
Member: 321515
Thanks Meter: 2
pls advice 1.1308 update system of naviplus 3000 and 3000s are compatible?
Old 01-17-2019, 06:23   #144 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 255
There is no different. Update with file at root of SD card
Sent from my SAMSUNG-SM-G935A using Tapatalk
Old 01-17-2019, 06:30   #145 (permalink)
Member: 321515
Thanks Meter: 2
thanks a lot sir Stunman112!!!
Old 01-17-2019, 09:31   #146 (permalink)
Miluk's Avatar
Member: 384541
Thanks Meter: 101
I know that is off-topic but there is possible to buy only lcd for pro3000s. Mine was broken after the programmer fell off the desk, and now is only white without and content. Touch screen working ok.
I will be very grateful for any information.
Old 01-17-2019, 15:46   #147 (permalink)
Member: 714887
Thanks Meter: 2
hello what is the official support of navi plus because I have the problem that after updating does not leave the logo
Old 01-22-2019, 00:37   #148 (permalink)
Member: 2828198
I posted once before about my screen issues and someone said they had a screen but are not responding to PM’s. Anyone seen this before? I have checked all connections and cannot fix, assuming bad lcd. I haven’t used this thing more than a week when it started. Of course the folks in China could care less.
Old 01-22-2019, 08:32   #149 (permalink)
Member: 883886
Sonork: 1664059
Thanks Meter: 111
Cool NEW NAVIPLUS PRO3000S Programmer
https://www.facebook.com/photo.php?f...Wh5CM4u2WwhRot
iPhone 8/8 Plus/X 3 in 1 ALS (Ambient Light Sensor) adapter for NAVIPLUS PRO3000S Programmer
Please note: This item can only be used for original screens, aftermarket screens are under developing.
This PRO3000S ALS Adapter is used to solve ambient light sensor not working issue after screen replacement.
To solve the auto-brightness issue by reading the firmware data of the original screen, and write the information into the replacement screen.
Need upgarde your pro3000S machine to latest V1.1307: https://drive.google.com/file/d/1ksA...kAhVAwXbQ/view
Old 01-22-2019, 08:41   #150 (permalink)
Miluk's Avatar
Member: 384541
Thanks Meter: 101
Have the same problems. I resolder all components on lcd flex and lcd start working for couple months. And 6 month ago was the same situation. Again resolder all on lcd and working. Now some days ago when fall down from desk, resolding not working, and lcd stay blank.
So for 90% is faulty lcd.
The is some supporter for this kind of parts or maybe factory support?
Page generated in 0.31249 seconds with 10 queries
