Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
View Poll Results: we must have an oscilloscope to repair hardware | |||
yes | 1,117 | 72.39% | |
no | 437 | 28.32% | |
Multiple Choice Poll. Voters: 1543. You may not vote on this poll |
03-27-2014, 07:43 | #257 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: Saudi Arabia Age: 39
Member: 675260 Status: Offline Thanks Meter: 30 | Quote:
Some people did not want anyone to learn And develops . | |
05-04-2014, 16:40 | #258 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Home Sweet Home
Member: 1322701 Status: Offline Thanks Meter: 127 | hello bro i need to learn how to use Osciloscope. how do i go about it? Quote:
09-28-2015, 17:42 | #265 (permalink) |
Freak Poster Join Date: Apr 2003 Location: Dublin Age: 43
Member: 25852 Status: Offline Thanks Meter: 31 | Have frequency generator and oscilloscope but i never really use it ... My handy tools are Cheap tinny multimeter and lab power supply .... You can check dead processor on Power supply if PWR Button OK and no power consumption after press 99% CPU fault ...If low power consumption between 10-80mAh then Boot or software ...to much time consuming to use oscilloscope and hardly needed as if you don't get TX you won't get RX so if you have output but no reception it is IMEI or BASEBAND ....It is really faster to just check frequency filters for output than connecting osciloscope ... If you have bad reception like 1 bar where you should get 4 you can check with osciloscope as maybe diplexer switch can be broken but if you have expirience you can simply solder new and see how it goes .... for old phones like 3310,3210,6310 you could simply jumper diplexer and see if signal is ok ...Not many new phones get problems with FREQUENCY ... But if they do for example if quartz is bad you can just use STOPER and check if time is correct usually within minute if there a big time difference QUARTZ is the problem ... |
Which is the best gsm field to Work??? | sallu | GSM Programming & Reverse Engineering | 8 | 03-22-2007 07:14 |
what is the best route to buying cdma equipment | jesto80 | Various CDMA/TDMA Cell Phones | 1 | 03-13-2007 04:01 |
HackGSM web site updated. Jouin Us for the best GSM equipment and price for it! | hackgsm.net | Main Sales Section | 0 | 03-27-2005 11:59 |
All the best GSM Hardware devices! | stargsm | Main Sales Section | 0 | 03-11-2003 19:53 |
