Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
01-07-2007, 18:51 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | please help with T862 rework station bulb lifetime i have heard that it can be with a redesign or i mean with making modification in the bulb circuit to do that, pleeeeeeeeeeeeeeeeease help ... |
01-07-2007, 20:08 | #2 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | buy good brand bulb(OSRAM) Quote:
Buy it good brand like osram 12v 150w ..i think this sutable for your rework station..this is verry good and long lasting bulb...this using in PDR infra rework station | |
01-13-2007, 22:18 | #5 (permalink) |
Member: 6524 Status: Offline Thanks Meter: 246 | You are compleatlly wrong mate Iam using last 2 years PDR INFRA REWORK STATION...I have never changed bulb (12V 150W)till now....... who told u this wrong info? osram bulb life only 50 hrs??? and lasting 2 weeks only???. this bulb cost is nearly 100£..Pls Don't misunderstand others.. |
01-14-2007, 01:22 | #6 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | well, i took with your advice but i can find only osram 12v 100w no higher than that & it works fine till now & i think i like it & i trust it too & i'll keep searching for the 150w , many thnx for your advice again Mr. GSMsurgeon & best regards ... |
01-15-2007, 06:05 | #7 (permalink) |
Junior Member Join Date: Sep 2006
Member: 350617 Status: Offline Thanks Meter: 1 | Hi, Click the data sheet button after going to the link below. It says 50 Hours. http://www.gilway.com/shopping/shope...?id=746&cid=52 The bulb is OSRAM 64635 Gold. Are u using something else ? Or perhaps u are not using your PDR too much. I have just stated using a PDR and within a week the bulb has ****n. I had not used it for the last two years!. I've now got it replaced. Let me see if it lasts longer. |
01-29-2007, 04:53 | #8 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | hi all ppl , just picked up some techincal information from that link Application Information Applications · Heating / infrared - temperature at focus point approximately 1,300 °C · Soldering · Welding WARNING The lamp emits ultraviolet (uv) radiation and operates at high internal pressure. Before use read the complete warning accompanying the product. Disposal When disposing of spent lamps, always consult federal, state, local and provincial hazardous waste disposal rules and regulations to ensure proper disposal. i hope every one read this well br., Raheeeeb |
11-16-2010, 02:52 | #9 (permalink) |
Junior Member Join Date: Oct 2003 Location: LEICESTER Age: 42
Member: 42645 Status: Offline Thanks Meter: 0 | t862 motherboard support i there why were on the subject i'm thinking of getting one of these tools does any body know if thay support xbox 360 ps3 laptops motherboard ,i know thay support mobile phones are thay any good and also do you get a support manual on the chip your dealing with so you don't knacker the chip up were can you get the heat setting from for the chips graphic gpu any ideas sorry if i jumped in to the forum but i thort this be the best place to put it |
11-17-2010, 05:30 | #10 (permalink) | |
Freak Poster Join Date: May 2007
Member: 515830 Status: Offline Thanks Meter: 80 | Quote:
forget reball ps3 with that there are a lot of modds for t862 for increase preheares to 150c excuse my bad english. bye | |
12-20-2010, 22:32 | #11 (permalink) |
Junior Member Join Date: May 2001
Member: 4800 Status: Offline Thanks Meter: 2 | Hi 4 all Does this lamp is better than the one that cames with T862++? HLX 64634 150W 15V EFR GZ6.35 Foto-Film-Stage Osram SVETILA.com Thanks in advance |
The Following User Says Thank You to Roadkiler For This Useful Post: |
02-15-2011, 16:36 | #12 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: France
Member: 19927 Status: Offline Sonork: joe-lindien Thanks Meter: 58 | Quote:
50hours for 50€ is not very expensive. For reballing GPU you use 1 minute maximum for remove and 1 minute maximum for reball and you take 50€ from customers. 50hours=3000minutes repair one GPU=2minutes and cost 50€ maximum 3000minutes=1500 GPU repaired 1500GPurepaired=1500*50=75000€ if 50€ is expensive for customers 30€ is the best price i think. 30*1500= 45000€ My reasoning is good? | |
please help with j220 can´t connect with setool | pachicoo | Sony Ericsson | 1 | 01-25-2008 18:42 |
please help with flash t230 gdfs with ufs3 | markLEE | Sony Ericsson | 2 | 09-27-2006 20:08 |
Please help with info (SE debug), and I will try to help with repair | Alkapone | Sony Ericsson Hardware Repair | 0 | 01-17-2006 20:34 |
6310 with audio broken track.Please help with schematic... | xchris | Nokia Hardware & Hardware Repair | 2 | 04-30-2004 23:08 |
PLEASE PLEASE PLEASE Help with BE5!!! | SVH | Alcatel & TCL Old Models | 1 | 08-03-2003 23:28 |
