Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
08-11-2014, 02:56 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | Questions about ir station/lcd&glass fixing glue/lcd&glass seperator secondly which lcd/glass seperator is good in working (which brand and model) because there are many videos on youtube ,mostly use string,cards etc now come to glue which fix lcd with glass,so how u people fix perfectly lcd with glass ,and wat glue of which brand u use ? Is glue is neccessay to use or not ? And how many of u use soldering wire which melts slowly i thing its called alloy doc Kindly answer these questions and share ur experiences too to make this thread useful for newbies also |
08-13-2014, 01:15 | #4 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | reply and up this thread,because if members contribute in this thread and sharing how they remove samsung glass,and how they fix glass with perfection etc than its very very useful for forum members |
08-21-2014, 14:43 | #6 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | for my knowledge i buyed a normal with manual wire and digital temperature set, i dont think that the so called semi-automatic worth the value, but now has arrived vacuum, that seems interesting but i have never used so far. for separation best tool is patience i'd like to learn some tricks too. for me the most difficult is removing the adhesive below lcd on samsungs... regards |
08-22-2014, 14:07 | #8 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | For me its always risky if touchpad is ok and display/lcd is bad or display/lcd is ok and touchpad is bad... mostly i do when touchpad broken or bad then i use hot air gun for heat touchpad and use blade to separate and when touchpad ok and display bad then risky dont use hot air gun just using blade ... but its truely risky i think some kind of model glue is very hard and want to learn from all of u............ |
08-22-2014, 14:15 | #9 (permalink) |
Member: 31028 Status: Offline Thanks Meter: 56 | yes there different types of glue, per example iphone 4 itself has different type not only brand different, so u have to set temperature right... the glue most not resist to wire if we apply many effort it may be because glue is not melted yet regards |
08-22-2014, 14:21 | #10 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | Yes agree with all of u , its very helpful and appreciating if u post videos or pictures tutorial of ur own work not from youtube |
09-04-2014, 20:06 | #11 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Regarding separation... well.. I guess all "manual" machines are almost the same as long as the digital temperature is correctly working. Different brands and models need different temperature to be able to remove the glass in a smooth way. Patience is btw the best thing Regardi Irda, I personally use the mopdel T-862++ and I find it ok., depends on the type of job that you have to do. Cheers X4ce |
