Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 01-16-2020, 12:20   #1 (permalink)
Member: 934255
Thanks Meter: 63
Solder doesn't stick on usb conector why?
Hello, i bought the micro usb conector from diferent supliers...
Same micro usb charge conector the solder glue perfectly... in other the solder doesn,t stick..
anone already have the same problem?
Already change iron, plut flux, temperature etc..
i think maybe is the quality of the metal on same usb charge conector...
Iron is beetween 300 and 450 degrees..
but is not iron problem because some conector the solder stuck easily..
any way to pass this problem?
tanks
Old 01-16-2020, 13:00   #2 (permalink)
biaby's Avatar
Member: 523332
Thanks Meter: 273
lemon .................................................. .
Old 01-17-2020, 08:16   #3 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
tanks
hello
before of to solder any connectors whatever its nature you should always clean tin residues with braid this facilitates the cohesion of the tin .
Remember
good flux
good tin
temperature on iron stable to 350° i advice to use copper tips are economic and great performance.
The Following User Says Thank You to orx For This Useful Post:
Page generated in 0.15278 seconds with 8 queries
