Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 09-03-2014, 20:10   #1 (permalink)
Member: 2001930
Thanks Meter: 17
Touch issue after lcd cleaning
Hello everyone
I have tried to separate about 15 screens and whenever i have i have issue with the touch after separating and cleaning. I use a big blade so that maybe an issue, also i tend to press a little hard. i do use a debonder though.
I set the hot plate to 80-90 degrees..
I am fairly new to this and have been trying this on the iphone 4/4s screen
Has anyone else had this issue and can provide me with a solution?
Old 09-03-2014, 20:27   #2 (permalink)
danisajee's Avatar
Member: 755480
Sonork: 100.1609798
Thanks Meter: 233
I had same issue when iwas try first time...in my option problem bcz of over heat... Place lcd after plate heat... I hope this will help you...
Old 09-03-2014, 20:37   #3 (permalink)
Member: 2001930
Thanks Meter: 17
I do place the lcd after heating the plate. What temperature do you set the plate for iphones?
Old 09-08-2014, 06:58   #4 (permalink)
Member: 2098114
Thanks Meter: 5
if you use lcd separator you can separate iphone lcd with wire at 67 degree it's the perfect temperature and put lcd on the plate after it reached temperature
The Following User Says Thank You to fulmicotone1 For This Useful Post:
Old 09-16-2014, 01:00   #5 (permalink)
Member: 2001930
Thanks Meter: 17
i still require help. im thinking of selling my machine and using a heat gun/ hairdryer. Is that a sensible choice to make?
Old 09-16-2014, 01:37   #6 (permalink)
DerryTM's Avatar
Member: 1857482
Thanks Meter: 137
No its not as correct heat and heat distribution is hard to do with heatguns and hairdryers
The Following User Says Thank You to DerryTM For This Useful Post:
Old 09-16-2014, 02:27   #7 (permalink)
Member: 2001930
Thanks Meter: 17
My issue is the touch, and I have heard the cutting wire is damaging the touch: that is why I think I should maybe use hear gun instead.
Old 09-16-2014, 04:23   #8 (permalink)
griff26's Avatar
Member: 192663
Thanks Meter: 31
On the iphone 4 and 4s when you take off the broken glass and remove the glue it is normal for the touch to be unresponsive,they need a layer of glue to respond to touch properly. So all those screens that you practiced on are probably still ok. If you have UV glue and UV light then apply new glue and fit new glass screen. Youtube is a good place to see all the different ways of doing this.
The Following User Says Thank You to griff26 For This Useful Post:
Old 09-16-2014, 08:08   #9 (permalink)
Member: 2001930
Thanks Meter: 17
Can someone else verify that? I don't want to waste this expensive glue I bought
Page generated in 0.20135 seconds with 8 queries
