Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 04-11-2014, 16:03   #1 (permalink)
Member: 2164014
Cool ULTRASONIC Cleaner, Cleaning Solution and more
hi guys, i would like to share experience about Ultrasonic cleaning process.
How do you act when you face on a liquid damage?!
Is the ultrasonic cleaner a necessary equipment for your lab?
Which is the best brand for PCBs cleaning?
What about cleaning Fluids and solutions?
Old 04-11-2014, 19:43   #2 (permalink)
Member: 1930199
Sonork: 100.1641048
Thanks Meter: 3
Same question
Old 04-12-2014, 01:34   #3 (permalink)
Member: 21937
Thanks Meter: 279
its a must have .... im sure someone who dont have it will tell you he clean everything without it .... but when you have it , you know you ware wrong before
buy one , its not expensive and its worth the money !
i have something like that
Globe 110V/220V PS 10A 80W Digital Ultrasonic Cleaner 2L Cleaning machine Jewellery Clean free basket-in Ultrasonic Cleaners from Home Appliances on Aliexpress.com
its very powerful and do the job well
buy 1 with metal body , i had another one with plastic body and the body broke by the use of the cleaning matirial
good luck
The Following User Says Thank You to TRABEL For This Useful Post:
Old 04-12-2014, 17:56   #4 (permalink)
Member: 2164014
When customers comes with water damage phones the first thing i do is to tear down the motherboard and brush it with isopropyl alcohol99% and a soft toothbrush.
After brushing is complete i wash the motherboard in the ultrasonic cleaner.
After cycle is completed i wipe and dry it with HOT AIR GUN (852d+ Rework Station) at 100C° and lowest power air.
i use this one (AOYUE 9050) and i can definitely tell that it is Very BAD Cleaner i don't recommend .
A good Ultrasonic Cleaner must have at least:
-TIMER function so you can select how long the washing time must go on.
-HEATER to warm up the cleaning fluid and improve the cleaning process to remove oxidations.
Optional functions:
-SWEEP function to prevent the motherboard sensible components to be ruined by ultrasonic waves.
Cleaning fluids:
To fill the ultrasonic cleaner Tank i use isopropyl alcohol99,9%. I never tried other cleaning solutions and i really would like to share experience of someone that had tried something like SEA CLEAN2 products or different cleaning fluids.
Im scared about the cleaning fluids that need to be dilute with water because i think it will generate more oxidation. feel free to contradict me please
now i ordered an Elmasonic product and i will share my experience soon.
Old 04-14-2014, 23:40   #5 (permalink)
Member: 7844
Thanks Meter: 182
to clean just 1 pcb at a time best is to get 0.8L or 2.0L ?
0.8L Digital
Digital Time Control
Power: 50 Watt
Tank size: 0.8L
Tank Internal Dimension: 150 (L) x 85 (D) x 65 (H) mm
Weight:1.1KG
Timer: 0-30 min
Ultrasonic Frequency: 42,000 Hz
1 Transducers
2L Digital
Digital Time and Heat Control
Power: 60 Watt
Heat Power : 50 Watt
Tank size: 2.0 L
Tank Internal Dimension: 150 (L) x 135 (D) x 100 (H) mm
Weight:1.9KG
Timer: 0-30 min
Temperature : 20-80 Degree
1 Transducer
Old 04-15-2014, 13:33   #6 (permalink)
Member: 2164014
Hi sir, what kind of pcbs you want clean? And why you want clean it with ultrasonic cleaner?
In my opinion the one with heater could be better solution for removing oxide from water damaged pcbs. If you planning to use it just for cleaning purposes such as removing flux after soldering process, or oil, dust or some organic residues you can easily choose the one without heater. :-P
Btw heater or not the most important thing in ultrasonic cleaning process is the cleaning fluid to use with.
I'm not so expert to recommend you in this choice because I use just isopropyl alcohol99,9%.
Is better to wait someone more expert than us ;-)
Old 04-15-2014, 17:43   #7 (permalink)
Member: 7844
Thanks Meter: 182
i need to clean water damaged gsm PCBs , i had 1 cleaner but i burnt it , need to buy 1 professional . i too use iso & ethanol
Old 05-02-2014, 06:52   #8 (permalink)
Member: 290789
we use ultrasonic cleaner 15l at our store for water damage repairs, we have found that using the proper procedures and solution is critical
we used to use denatured alcohol which did clean some boards, but we had to experiment with different chemicals to get the best results and remove the corrosion or rust
Page generated in 0.16627 seconds with 8 queries
