Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
04-11-2014, 16:03 | #1 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2164014 Status: Offline Thanks Meter: 1 | ULTRASONIC Cleaner, Cleaning Solution and more How do you act when you face on a liquid damage?! Is the ultrasonic cleaner a necessary equipment for your lab? Which is the best brand for PCBs cleaning? What about cleaning Fluids and solutions? |
04-12-2014, 01:34 | #3 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
buy one , its not expensive and its worth the money ! i have something like that Globe 110V/220V PS 10A 80W Digital Ultrasonic Cleaner 2L Cleaning machine Jewellery Clean free basket-in Ultrasonic Cleaners from Home Appliances on Aliexpress.com its very powerful and do the job well buy 1 with metal body , i had another one with plastic body and the body broke by the use of the cleaning matirial good luck | |
The Following User Says Thank You to TRABEL For This Useful Post: |
04-12-2014, 17:56 | #4 (permalink) |
Member: 2164014 Status: Offline Thanks Meter: 1 | When customers comes with water damage phones the first thing i do is to tear down the motherboard and brush it with isopropyl alcohol99% and a soft toothbrush. After brushing is complete i wash the motherboard in the ultrasonic cleaner. After cycle is completed i wipe and dry it with HOT AIR GUN (852d+ Rework Station) at 100C° and lowest power air. i use this one (AOYUE 9050) and i can definitely tell that it is Very BAD Cleaner i don't recommend . A good Ultrasonic Cleaner must have at least: -TIMER function so you can select how long the washing time must go on. -HEATER to warm up the cleaning fluid and improve the cleaning process to remove oxidations. Optional functions: -SWEEP function to prevent the motherboard sensible components to be ruined by ultrasonic waves. Cleaning fluids: To fill the ultrasonic cleaner Tank i use isopropyl alcohol99,9%. I never tried other cleaning solutions and i really would like to share experience of someone that had tried something like SEA CLEAN2 products or different cleaning fluids. Im scared about the cleaning fluids that need to be dilute with water because i think it will generate more oxidation. feel free to contradict me please now i ordered an Elmasonic product and i will share my experience soon. Last edited by Milord85; 04-12-2014 at 18:02. |
04-14-2014, 23:40 | #5 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | to clean just 1 pcb at a time best is to get 0.8L or 2.0L ? 0.8L Digital Digital Time Control Power: 50 Watt Tank size: 0.8L Tank Internal Dimension: 150 (L) x 85 (D) x 65 (H) mm Weight:1.1KG Timer: 0-30 min Ultrasonic Frequency: 42,000 Hz 1 Transducers 2L Digital Digital Time and Heat Control Power: 60 Watt Heat Power : 50 Watt Tank size: 2.0 L Tank Internal Dimension: 150 (L) x 135 (D) x 100 (H) mm Weight:1.9KG Timer: 0-30 min Temperature : 20-80 Degree Ultrasonic Frequency: 42,000 Hz 1 Transducer |
04-15-2014, 13:33 | #6 (permalink) |
Member: 2164014 Status: Offline Thanks Meter: 1 | Hi sir, what kind of pcbs you want clean? And why you want clean it with ultrasonic cleaner? In my opinion the one with heater could be better solution for removing oxide from water damaged pcbs. If you planning to use it just for cleaning purposes such as removing flux after soldering process, or oil, dust or some organic residues you can easily choose the one without heater. :-P Btw heater or not the most important thing in ultrasonic cleaning process is the cleaning fluid to use with. I'm not so expert to recommend you in this choice because I use just isopropyl alcohol99,9%. Is better to wait someone more expert than us ;-) |
05-02-2014, 06:52 | #8 (permalink) |
Junior Member Join Date: Jun 2006 Location: USA
Member: 290789 Status: Offline Thanks Meter: 1 | we use ultrasonic cleaner 15l at our store for water damage repairs, we have found that using the proper procedures and solution is critical we used to use denatured alcohol which did clean some boards, but we had to experiment with different chemicals to get the best results and remove the corrosion or rust |
