Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Equipments for GSM
Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext.
Old 01-26-2005, 11:55   #136 (permalink)
Invisible's Avatar
Member: 3956
Sonork: galletto3 rules :D
Thanks Meter: 55
Originally Posted by zulea
This tool work ONLY on PKD-1 dongles and NOT work on FLS-x. Don't even detect dongle if you use any FLS-x
Best regards,
Zulea
hi,
nice joke, this tool is not working....
after write dongle, unplug&plug still regular PKD-1...
also I noticed R&D dongles are 6 digit 2xxxxx while regular PKD-1 is 5 digit,
no sure PKD-1 5 digit can be activated to R&D
src:
Memo1.Lines.Clear;
Memo1.Lines.Add('PKD Type write OK');
best regards
Invisible
Old 01-26-2005, 13:33   #137 (permalink)
epic's Avatar
Member: 10635
Thanks Meter: 10
same here, even press 10x still same as before.... ;(
BR,
epic :0
Old 01-26-2005, 13:35   #138 (permalink)
epic's Avatar
Member: 10635
Thanks Meter: 10
Only sure and 100% way to do this is to do it the " hard way"
BR,
epic
Old 01-26-2005, 13:37   #139 (permalink)
Invisible's Avatar
Member: 3956
Thanks Meter: 55
@Treoo:
what kind of PKD-1 did you updated? 5 digit or 6 digit?, also please post your OS and LPT bios mode (EPP, ECP...),
I tryed on XP (intel&amd mcu), LPT port on EPP, LPT port on ECP, no success...
I guess this not working at all
best regards
Invisible
Old 01-26-2005, 13:42   #140 (permalink)
epic's Avatar
Member: 10635
Thanks Meter: 10
Cool
Originally Posted by Invisible
hi,
best regards
Invisible
Hi,
5 digits PKD-1 can be activated to RD and same time become 6 digits... tested the " hard way"...
BR,
epic
Old 01-26-2005, 13:48   #141 (permalink)
Invisible's Avatar
Member: 3956
Thanks Meter: 55
Originally Posted by epic
Hi,
BR,
epic
yeah, "hard way" is still the only choice,
I lost your previous mail,
best regards
Invisible
Old 01-26-2005, 15:16   #142 (permalink)
Member: 1060
Thanks Meter: 10
long time ago, since NOKIA release PKD-x by use the 3ASIC, i did research ,
and most time "xor" is one so much use at the eeprom !
you can try to do it from "serial" number !
now, for me to have "5 or 6" digits PKD-x, it same !!
it all can be make any PKD-XX what i like !
try to do "xor" !
Willy
Old 01-29-2005, 17:57   #143 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
Don't know about you guys but my PKD-1 is now a perfectly working PKD-1RD
Works fine to me
Old 01-30-2005, 17:15   #144 (permalink)
Zaihtam's Avatar
Member: 98572
Thanks Meter: 36
My 5 digits pkd-1 now become the PKD-1R&D, it works 100%.
Just RunThe software, after writing done, unplug, and plug it again (Reboot the Motorola MCU). Then 100% working.
Old 01-30-2005, 20:10   #145 (permalink)
Invisible's Avatar
Member: 3956
Thanks Meter: 55
Originally Posted by Treoo
Try install all drivers and etc and maby even lamers have it work..
Lamers, blah, blah, blah, why donīt you reply what I asked few post before:
@Treoo:
btw, my dongle have DES2Asic inside, what asic inside yours?
best regards
Invisible
Old 01-31-2005, 07:35   #146 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
@Treoo:
best regards
Invisible
Your EEPROM in your PKD-1 is low supplyed (under voltage) and depend of EEPROM used chip/manufacturer it can not perform write operation.
You can try on very old PC (who give 5 volts levels on LPT and not 3.3 volts) or change EEPROM in your dongle with a low voltage one.
Another way is to supply all PKD-1 hardware (MCU + EEPROM) from external power supply with 5 volts. Check PKD-1 schematics to see where to cut wires and to supply voltage.
Best regards,
Zulea
Old 01-31-2005, 09:51   #147 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
Mine is a PKD-1 6digit and i upgrade it successfully to RD
i dont care about asic because it works and that's fine to me
Thnx zulea
Old 01-31-2005, 10:57   #148 (permalink)
Invisible's Avatar
Member: 3956
Thanks Meter: 55
from the Treo pictures I saw he had a 6 digit dongle 2xxxxx,
uhmm, I am checking my dongle when having little time, perhaps I run low on voltage
thanks Zulea for the hint!
best regards
Invisible
Old 01-31-2005, 15:10   #149 (permalink)
epic's Avatar
Member: 10635
Thanks Meter: 10
This is what I like with Daniel, giving out support to those in need of support for his software.. keep up the good job..
BR,
epic
Old 01-31-2005, 15:58   #150 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
I want to ask sommeone if knows what kind of tipe is ic des 2acs ds1 and where i can fin somme information about it , or if i can replace vith someting else .
Tnx .
latest winlock of pkd-rd/mt-box??? andrew14 MT-BOX 0 11-24-2006 03:59
Original PKD-1 to PKD-1 RD NBG Nokia Hardware & Hardware Repair 0 05-25-2005 01:31
Selling PKD-1 dongle upgraded to Pkd-1 RD gsmfolly Sell ur Old and Used Stuff 13 03-09-2005 22:49
Upgrade of PKD-1 to RD MRXSG Wanted Products 2 11-28-2004 19:59
Page generated in 0.12763 seconds with 10 queries
