Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
02-18-2014, 05:00 | #1 (permalink) |
Junior Member Join Date: Apr 2013 Location: FL
Member: 1928138 Status: Offline Thanks Meter: 1 | SOLDERING STATION ATTEN AT937b or Hakko FX-888D?? Which one do you think is suitable for Phone and Tablet Repairs? and Why? Hakko FX-888D almost $100 Temperature Range: 120° - 899°F (50° - 480°C) Temperature Stability: ±1.8°F (1.0°C) Temperature Control: Closed-loop sensor Model Name: FX-8801 Power Consumption: 65W / 26VAC Tip: T18 Series Standard Tip: T18-D16 (shape 1.6D) Tip-to-Ground Resistance: < 2 ohms Tip-to-Ground Potential: < 2mV or ATTEN AT937b almost $50 Specifications: Power voltage: AC120V 60Hz Power Consumption: 50W Temperature Range: 220℃~480℃ Output voltage: 28VAC Tip Leakage Voltage: <0.5mV Standard Tip: 900M Thanks in advance, |
02-18-2014, 14:57 | #2 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
The Following User Says Thank You to allumts For This Useful Post: |
