Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
View Poll Results: Your opinion about .
Definitely worth, result is like original. 65 29.95%
Its not like original but very close. 64 29.49%
Result is not so good but for such a price it worth. 53 24.42%
Not worth at all, i prefer original spare part. 35 16.13%
Voters: 217. You may not vote on this poll
Old 04-11-2014, 15:30   #16 (permalink)
Member: 2164014
For phones like Samsung S series changing the glass only means that after some weeks the possibility to have the screen glass broken again or dust between lcd panel and glass is too high! 80% of the phones repaired in this way will face off this problem. i think applying the LOCA gel and refurbish the display is definitely the best way.
Old 04-21-2014, 00:11   #17 (permalink)
Member: 93210
Thanks Meter: 12
for any samsung i use hot hair gun of my wife its easy, i remove old expoxy, put new loca glue and put glass, i press and fix corner with laser uv and put in uv box 2 min and 100% perfect, 0% defective
Old 04-22-2014, 15:27   #18 (permalink)
COMPAQ's Avatar
Member: 18462
Thanks Meter: 30
seems hot hair gun of ur wife is very efficient...but use it carefully.regards
Old 04-29-2014, 07:59   #19 (permalink)
Member: 1805996
I have changed glass from iphone 5 for first time last week unfortunately the glue had leaked under between lcd and backlight. Is this a comment problem? It was first time for me refurbishing screen. I used 0.7ml glue put pussed to hard on the glass i think....
Old 05-02-2014, 21:09   #20 (permalink)
RedeYeS's Avatar
Member: 36706
Sonork: 100.58560
Thanks Meter: 122
its better romove back light before putting uv glue as iphones lcd`s are different from samsungs , they have separated light source not integrated like samsung and uv glue can leak , so separate back light , attache glass and then put back back light
br
The Following User Says Thank You to RedeYeS For This Useful Post:
Old 09-11-2014, 14:52   #21 (permalink)
Cermis's Avatar
Member: 14887
Thanks Meter: 29
Our B2B company access over 5000+ LCD every month, we are now looking for a professional refurbishing company in Europe. White great experience in Refurbishing on production line level.
Were can I find a company like this?
Thanks in advance!
Old 09-13-2014, 18:00   #22 (permalink)
Member: 1882599
Thanks Meter: 2
I had this one
LCD Separators : LCD Separator Machine - LY946D for Iphones and others 110V
Then I upgraded to this one that allows me to do Ipads
LCD Separators : LCD Separator Machine - LY950 for Ipads and others 110V
Old 01-11-2015, 10:14   #23 (permalink)
Member: 1736451
Thanks Meter: 6
what is the best solution to remove the glue after removing the glass?
Old 01-11-2015, 16:13   #24 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
in my experience :
clean level =
1- specific china remove glue = negative result
2- isopropyl alcool = good and fast to remove
3-Use brake cleaner car garage-based aviation gasoline results fast and perfectly melts the glue, careful not to insist too much on display ... still preserves the plastic parts.
first test it on a display failure ..
http://www.eb**y.it/itm/TUNAP-215-DE...p2054897.l4275
The Following 2 Users Say Thank You to orx For This Useful Post:
Old 02-07-2015, 22:37   #25 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
In my shop enter from friend that replace these almoust 3/4 pieces for day becouse Touch Not work more.
90% are Galaxy Mega and Grand all with Sw side damaged, i not replace these but these friend have good profit from this work, (when not damage nothingh).
Anyway can have good result w/o this machine whith Best UV-Loca glue and other strument, not indispensable spent all these money for this machine and have very good result the same
Old 06-13-2015, 14:25   #26 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
Originally Posted by orx View Post
remove
You mean that brake cleaner destroys displays?
Old 06-14-2015, 09:20   #27 (permalink)
allumts's Avatar
Member: 1564612
Not use these BAD product never!!!
Lcd can be permanent damaged with big spots, all plastic part will corrode even with a barb...
This method of Trieline, or other Invasive was used only for Oxide removing first all plastic part, (1000 time more good the TIP of the rice of kitchen)....
Now in the market, Not to buy Economy CHINA product, there are many products and protection for remove Glue w/o damaging nothing...just not search in Economy not tested product...Warning when you want do money replace one glass and damage one LCD is more good change work...
allumts
Old 06-15-2015, 10:30   #28 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
you can use them safely, used and tested no problem with plastic and no bubble ..the basis of this liquid removal is aviation gasoline.
This is used not only by me but also by other laboratories and is for sale on ebay :
http://www.e**y.it/itm/200-Solvente-...item4d1eff703b
Old 06-15-2015, 13:52   #29 (permalink)
allumts's Avatar
Member: 1564612
And this product selled in Ebay Italy is the most economic product for remove this glue...this BAD product if you do wrong...leave LCD with irreparable stains...is my opinion that if you want do one work must need of more good product in the market....never i use one Economic product for to see muy customer back in my shop...
There's a proverb:
" who save not earn "
allumts
Old 06-15-2015, 17:05   #30 (permalink)
Member: 594086
Thanks Meter: 9
i have been using glass replacement there is no complain but somtime when removing old glass i break the lcd can someone help what is the cause for that
Page generated in 0.25917 seconds with 10 queries
