Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
View Poll Results: Your opinion about .
Definitely worth, result is like original. 65 29.95%
Its not like original but very close. 64 29.49%
Result is not so good but for such a price it worth. 53 24.42%
Not worth at all, i prefer original spare part. 35 16.13%
Voters: 217. You may not vote on this poll
Old 02-02-2014, 23:12   #1 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
Are your customers satisfied after "glass only" refurbish method?
Share your experiences and opinion about the results of refurbished lcd-touch set.
it worth the time to spend for refurbishing?
Touch response has acceptable result?
How many of them returned because of defective reason after X-time?
The Following User Says Thank You to Platijet For This Useful Post:
Old 02-05-2014, 17:44   #2 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Thanks Meter: 88
My customers have been very happy(not had any back) with the glass repair, only takes me 20 min to do so its a quick repair and very good profit.
Could i ask if you have had issues with this type of repair?
WBR
Old 02-05-2014, 18:50   #3 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
Results are 80% compared with original displays and this is unacceptable for me, especially for phones like galaxy S4 and Note 2 . In service test menu, sensitivity and stability is poor and many times you have to touch twice.
Old 02-06-2014, 20:12   #4 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Thanks Meter: 88
I haven't had any of those issues. Been perfect for me.
Must remind customer if they want perfect job then pay for full screen replacement.
Want to pay for cheaper job then is going to be a cheaper finish?
WBR
The Following 3 Users Say Thank You to MFC For This Useful Post:
Old 02-06-2014, 20:19   #5 (permalink)
Member: 1693369
Thanks Meter: 25
Yap, no complain. Pay more to get more!
Sent from my GT-I9505 using Tapatalk
Old 02-07-2014, 07:49   #6 (permalink)
Member: 1347382
Thanks Meter: 85
Have been using loca glue and yes the repair is a lot cheaper and with the use of loca glue gives a better finish. It's all about learning the right techniques. Other people use tape only around the edges and it looks bad and the touch sensibility is affected.
Old 02-10-2014, 21:36   #7 (permalink)
Macie provider's Avatar
Member: 1652212
Thanks Meter: 73
WBR
dear MFC which tool do you use to replace the glass lens in 20 min? can you share your experience?
Old 02-11-2014, 00:24   #8 (permalink)
Member: 26623
Thanks Meter: 88
Maybe you need to use high quality Glass original or high copy, not cheap copy and also quality UV Glue
Old 02-11-2014, 01:25   #9 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
I used finest quality.
Old 02-11-2014, 16:06   #10 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Thanks Meter: 88
I bought my machine from FoneFunShop in UK.
Model: YOUYUE 948, i don't think it is better than any other but practice makes perfect and i had a lot of damaged screens to test on before hand.
Get correct temp and time, also for Samsung's i don't use wire to separate.
I use two iSesamo opening tools.
Actually takes me under 5min to separate, most of my 20min is taken by cleaning (Perfectionist ).
WBR
Old 02-12-2014, 10:43   #11 (permalink)
.::MEGATRON::.'s Avatar
Member: 1637410
Sonork: 100.1606885 QQ 2480697349
Thanks Meter: 127
WBR
You are using the machine for heating purpose ?
For me I am using air gun only to remove the glass
Old 02-12-2014, 19:18   #12 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Thanks Meter: 88
Yes, hotplate makes job so much easier, quicker and most importantly safer.
Very risky with hot air gun and not as good a job.
WBR
Old 02-15-2014, 10:20   #13 (permalink)
Registered User
Member: 57367
Thanks Meter: 12
i use IRDA rework bootom heat , plus holder plate, result almost as good as the lcd/screen separator machine
Old 02-22-2014, 05:00   #14 (permalink)
guddu ahmad's Avatar
Member: 1345926
Sonork: 100.1671229
Thanks Meter: 176
Bro. ....
up lode video please. .......
Old 03-12-2014, 02:24   #15 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
for me i changed it perfactly with hot air gun in 20min but some time it not perfactly working but its better from ic inbuilt wired touch because it take more time and less result for me however i remove it in less time and change d quickly but most time it not working perfactly. glass result is 80% positive and wired touch result 50% positive for me
Page generated in 0.29497 seconds with 10 queries
