05-14-2004, 23:23 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: mauritius
Member: 15162 Status: Offline Thanks Meter: 61 | Big problem for unlocking philips 350 I have try to unlock one philips 350 but it says:- Power ON Phone...OK! TAT MODE..OK! Reading Imei..OK! IMEI : 351660-00-518259 3 Reading Codes.. Communication Error !! Cable is 100000% ok have also try to read the flash it reads and stops at 6% and says remove battery and retry ,have try more than 10 times same problem. Power ON Phone...OK! Loading Boot........OK! Flash ID : 2010 Type : ST M58WR064B 8Mo PHILIPS PRODUCT : KMELEON Reading Flash...Error! Remove battry and retry! please help!!!!!!!!1 Thanks in advance yash |
05-15-2004, 07:30 | #3 (permalink) |
Member: 15162 Status: Offline Thanks Meter: 61 | Hi julvir Thanks for replying ,i am using latest version (philipsv2). will charge battery it was on 2 . why is does that:- Power ON Phone...OK! TAT MODE..OK! Reading Imei..OK! IMEI : 351660-00-518259 3 Reading Codes.. Communication Error !! is that version not supported ? |
05-19-2004, 08:31 | #7 (permalink) |
Member: 15162 Status: Offline Thanks Meter: 61 | @julvir Thanks great support Any solution for this one:- http://forum.gsmhosting.com/vbb/showthread.php?t=141152 Cheers Djyash |
05-19-2004, 17:47 | #9 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: Spain Age: 45
Member: 16165 Status: Offline Thanks Meter: 10 | Quote:
BesT RegardS ... | |
05-27-2004, 00:52 | #12 (permalink) |
No Life Poster Join Date: May 2002 Location: Spain Age: 54
Member: 12126 Status: Offline Sonork: 1575463 Thanks Meter: 199 | I bought a special cable from www.******.com for 350 and it works ok for unlock and entering in tat mode but I cannot use it with flashing and as I press connect I get this error Ready.. Power ON Phone...Error! File Size : 8388608 Byte(s). Power ON Phone...Error! so the only thing is with this cable I cannot connect in flash mode. With this cable we dont have to open phone and solder so its good but doesnt help in flash mode, this cable comes with external alimentation. any suggestions. regards bcnboy |
06-01-2004, 13:25 | #14 (permalink) |
Member: 12126 Status: Offline Sonork: 1575463 Thanks Meter: 199 | Or just use T191 cable but leave it little outside dont enter full pin in the phone and it works 100% I have tested with rvolume soft and Red box. Only with this you can enter in tat mode and read unlock codes or direct unlock but dont work for flashing. regards bcnboy |
big problem for unlock motorola by code | kakaomar | Phone Unlocking Codes & Maps | 3 | 06-08-2009 13:44 |
Proble unlocking philips 350 | after89 | Multi-Box | 8 | 02-13-2007 21:42 |
big problem for unlocking 1600 | MTi-GsM | UFS2 + UFS3-Tornadoflasher | 2 | 06-17-2006 16:21 |
Big.big Big Problem For All | clinic*mobile | Phoenix Black Box | 10 | 09-26-2005 15:58 |
How to unlock philips 350!!! | dexter2 | Philips | 4 | 08-10-2004 10:11 |
