Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SwS Team Products > Redbox
Old 07-11-2005, 06:02   #1 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 387
Box Not connected !!
Dear friend,
I just bought a new red box but when i run the program say LG comander, Its says that BOX IS NOT CONNECTED. i have tried a lot but its still does the same! The box is NEW and i have been able to used it at all... What are the solution?? What are the solution that i should take?? Please help me up!!
Old 07-11-2005, 06:24   #2 (permalink)
reo
reo's Avatar
Member: 4270
Thanks Meter: 13
make sure u have the .key file in the folder.
also dont connect power in the box til u have the paralllel cable plugged in.
and as a suggestion when u get this, i normally disconncet power reconnect wait till the light stops blinking and then start the program.
Usually this gets everything going
reo
Old 07-11-2005, 07:53   #3 (permalink)
ashvin's Avatar
Member: 106700
Thanks Meter: 47
Redbox is like that; its very unstable. i jnow only a few lucky guys who can statr there redbox in 1 go. For me i have found a solution to make redbox work. i plug in the usb cable and then i restart my computer with the redbox plugged. when my pc loads on the second times, upon 1 or 2 trial, redbox starts. u shoudl various ways to see how it works for u. i know some people who never restart their computer with redbox switch on. any way i hope there would be some sort of update one dy which will make redbox work like griffin in one go.
Old 07-12-2005, 00:35   #4 (permalink)
Seedy's Avatar
Member: 8102
Thanks Meter: 100
Try to read the Serial Number by using SN Reader - if it shows error then Redbox is not working - if it gives you a serial number - then give your reseller the serial number to get activation file to activate Redbox programs
Old 09-12-2005, 06:06   #5 (permalink)
Member: 82609
the easy way is : run software before you plug the usb power cable working 100%
good luck
my veking box not connect to box..help me acay VE-PRO BOX 4 02-23-2010 09:56
Sir My Ufs Box Not Connect Pleas Help Driver Not Conect shreecell UFS2 + UFS3-Tornadoflasher 1 01-19-2008 04:38
Red Box Says Box Not Connected Help ARAB GSM Redbox 3 04-12-2007 07:14
Solution for Box not connected ( RED BOX II) GSM SNIPER Redbox 8 12-03-2005 17:18
box not connect balLlroad Redbox 4 08-28-2004 21:52
Page generated in 0.25913 seconds with 8 queries
