Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SwS Team Products > Redbox
Old 10-06-2004, 23:14   #1 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Can i use Gx30 Usb cable to Unlock Gx30, Tm100 with Red box ??
All in topic
Thanks
Aamir Zia
Old 10-07-2004, 02:25   #2 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
Is the GX30 cable the same as the GX15/Nec cable ?. I have used the USB NEC cable to unlock the GX15. not sure if it is the same cable as the GX30
Old 10-07-2004, 05:19   #3 (permalink)
Member: 34054
You must use the serial cable or special made USB cable to unlock GX30 and TM100.
Schematic and connection diagram are in the RedBox support page.
Old 10-07-2004, 08:03   #4 (permalink)
Registered User
Moosani's Avatar
Member: 15866
Thanks Meter: 192
gx30 tm100 unlock via serial cable
gx15 nec525 unlock with same cable usb (this cable is in box of e606 e808)
thanks and best regards
How to unlock philips 355 with Red-Box? tetrasquel Redbox 2 09-17-2004 14:37
how to unlock lg l1100 with red box??? infogsm Redbox 3 09-15-2004 21:18
Can i use a v66 cable to unlock at720 JOHN2003. Motorola P2k 2 06-22-2004 16:16
Can i use a usb cable to flash gd87e a19 kieron555 Panasonic 7 03-08-2004 13:16
Can I use a Data cable to unlock SagemMC920? Irishrover Infineon C16X M51 & ARM7 M52 BASED 2 09-21-2003 19:10
Page generated in 0.15225 seconds with 9 queries
