07-09-2004, 19:28 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: germany Age: 45
Member: 37112 Status: Offline Thanks Meter: 2 | dead n22i after flashing Power On phone...OK. Talking to passive bootloader..OK. Synchronizing..OK. ROM Mask ID : 0x00004742 ID Register : 0x000203CD Maximum transfer size : 2056 Bytes Loading Boot..OK. Flash Type : Manufacturer : 0x002B Device : 0x001C Flash Description : Mitsubishi M6MGE157S4KT, 16 Mo Loading Flash File plz wait..OK Writing Flash..OK |
12-27-2004, 15:18 | #4 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Me too Quote:
While Flasjing, I selected "Flash eeprom Area", and after flashing now phone dead. I flashed again without selecting it, phopne still dead !!! What is solution now ? Thanks | |
01-27-2005, 12:57 | #5 (permalink) |
Insane Poster Join Date: Aug 2002 Location: Bucuresti, Romania
Member: 14940 Status: Offline Thanks Meter: 16 | Me too I face the same problem. I flashed a n22i with full flash and now phone is dead. If i look really careful into light i can see how the screeen turns white(no backlite) after 2 second dark again - this repeats after every 2-3 seconds. |'ve tried also flashing with "write eeprom" checked also - still the same - Julvir please respond - this is not an isolated case ! 10x |
01-28-2005, 02:25 | #7 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | I have flash like 4pcs 22i and 2pcs 223i all was ok Last 223i i have flash, phone flash 100% but not start. I have made all setings posible. @Aamir_Zia flashing process is already very slow, and red box like only com1 or com from usb phone driver. Com1 is very slow to make backup and reflash again... How to do to flash quicker???? (maybe not the place-but first time i see this) Regards |
08-19-2005, 14:21 | #9 (permalink) | |
Registered User Join Date: Nov 2002 Location: USA Age: 43
Member: 17846 Status: Offline Thanks Meter: 4 | Quote:
I TRIED FLASHING MORE THAN ONCE, BUT STILL EXACTLY SHOWING: If i look really careful into light i can see how the screeen turns white(no backlite) after 2 second dark again - this repeats after every 2-3 seconds... Plz i need an advice here.. | |
10-24-2005, 18:33 | #10 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | For me my Problem is like this:: ------------------------------- Power On phone...OK. Talking to passive bootloader..OK. Synchronizing..OK. ROM Mask ID : 0x00004742 ID Register : 0x000203CD Maximum transfer size : 2056 Bytes Loading Boot..OK. Flash Type : Manufacturer : 0x002B Device : 0x001C Flash Description : Mitsubishi M6MGE157S4KT, 16 Mo Loading Flash File plz wait..Incorrect File size !! Writing Flash..OK ---------------------------- But the phone do not swithc on!! Where can be the problem?? Where can i finnd a good corect file size of n22i flash files cause mine its says "Incorrect File size " Please help me up!! |
10-24-2005, 18:57 | #11 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | i have all version of NEC v2.4 to 3.4 !!! Of REDBOX which one should i used??? When using v3.4 its says TIME OUT! but older version it flash the mobile but it does not switch ON! |
10-24-2005, 22:04 | #12 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 107916 Status: Offline Thanks Meter: 30 | hi to all Quote:
i try to flash nec N22i like JULVIR say and now my phone is dead( before my phone diplayed please wait and the code for removing please wait does'nt work), and i thing if some one have to flash nec N22 i do not rewrite eeprom erea please you will kill your phone forever. leroi | |
10-25-2005, 01:25 | #13 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | hi man don't worry, i had the same probleme, my n22i was freezing on start up i flashed it with the latest software and it was dead, but i flashed it with another old soft and it become ok, try lower version of nec soft, i don't know what i have used, but i solved my probleme like that. good luck |
Need Help Dead V635 After Flash with V600 Flash (i didn't do it) | g0den99 | Motorola P2k | 3 | 10-08-2005 23:58 |
NEC n22i after flash no ringtones and images !! | chavrotti | Redbox | 1 | 06-29-2004 14:41 |
dead t192 after FLASHING with bad flash file | zdob | Motorola Old Legacy (EMMI) | 5 | 07-02-2002 18:30 |
dead t280 after flash with free flash | tkerek | Motorola P2k | 0 | 05-26-2002 16:22 |
Dead 3699 after flashing | unlockerbh | Motorola Old Legacy (EMMI) | 0 | 08-22-2001 17:49 |
