Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SwS Team Products > Redbox
Old 06-21-2005, 13:24   #1 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
failed to unlock nec525
hi
i tryed to unloc a nec 525 with redbox but everytime it gives an error
Ready..
Start : 13:12:01
Init Phone plz wait........Error
End : 13:12:16
Start : 13:15:56
End : 13:16:11
Start : 13:16:15
End : 13:16:30
any idea please
br
Old 06-21-2005, 17:00   #2 (permalink)
kenichi's Avatar
Member: 6084
Thanks Meter: 4
Try with 2.9 version.
Old 06-21-2005, 19:23   #3 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
i have tryed
3_0 , 3_A , 3_B , Nec29, Nec3_0, Nec_v31
but all the same
br
Old 06-22-2005, 23:20   #4 (permalink)
shadi's Avatar
Member: 35002
Sonork: 100.98829
Thanks Meter: 167
use usb cable install driver chek the correct com from device manger then open the soft choose the model and the com then press unlock
Old 06-22-2005, 23:21   #5 (permalink)
shadi's Avatar
Member: 35002
Sonork: 100.98829
Thanks Meter: 167
ma be your phone n525e !!
Old 06-24-2005, 00:42   #6 (permalink)
needi's Avatar
Member: 18303
Thanks Meter: 3
yes u can unlock it as 525e....if it is telling fone not supported.
Old 06-24-2005, 04:08   #7 (permalink)
Member: 2147
Sonork: 63246:Paderf
Thanks Meter: 20
Use last version .. in your case soft not detect even phone .. install usb driver for your phone and power on phone than start soft ..choose correct Com port and select your model than Read code.. if you got message "Phone not supported", go to Panel Update choose methode 1 than methode 2 if not succed, and click Unlock this methode will unlock all supported or unsuported Nec 2G(it will take more time than direct by choosing model).
Regards,
Old 06-24-2005, 05:20   #8 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 879
Originally Posted by chowdary
hi
Ready..
Start : 13:12:01
End : 13:12:16
Start : 13:15:56
End : 13:16:11
Start : 13:16:15
End : 13:16:30
any idea please
br
Use Cracked Furious - allways work just fine ... my own Redbox also work bad with N341i and N525 even sometime catch phone, say sending bootstrap ect... and finaly - contact for upgrade or phone unlocked but ... realy no.
WBR, DebeliaMark, BG
Old 06-24-2005, 07:02   #9 (permalink)
CHAPRAN's Avatar
Member: 31906
Thanks Meter: 100
I CANT ALSO UNLOCK 525 Init Phone plz wait........Error
Old 07-22-2005, 15:10   #10 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
I have same problem NEC 525e
Old 07-22-2005, 16:19   #11 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Thanks Meter: 16,353
Wrong COM PORT !!
Select right Com port
Old 08-06-2005, 00:55   #12 (permalink)
Seedy's Avatar
Member: 8102
Thanks Meter: 100
I just tried unlocking a 525 with Redbox and went through the unlocking process but at the end said New Model contact your dealer or something like that
However worked first time with Furious and my code was there
Failed to Unlock 2323c Using Super DCT4 Activation [Solved Thanks to Alex] tims Cyclonebox 7 07-31-2010 10:31
2680s RM500 keeps on failing to unlock! how to solve this??? Unlockemall Universalbox 14 02-20-2010 09:51
Z240 failed to unlock using " Fast Direct Unlock " A-H-T UST Pro II 23 11-06-2009 10:43
need help to unlock nec525 jab NEC 1 12-08-2004 08:44
Page generated in 0.37999 seconds with 8 queries
