Flash u81xx with REDBOX NOW!!!1! successfully flashed 4 u8120 today with redbox used as "max 232 interface"--- if i can say that just modify cable u81xx by ADDING ONLY USB connections to it and use FlashRW-040227-Multi-Release-SVC for flashing. serial port, parallel port and usb port is connect to redbox. works 100% for owners of redbox...... no need to buy flasher cable to downgrade u81xx phones WBR Mehvishal |
Red Box dont have usb port ! where did u attached the usb cable ? It has only one usb port for power supply in Red Box Mini Usb port ! |
use usb from your pc directly |
Ok ! tell me pinout for 8120 ! |
Keyboard up 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 21 link to 2 19 link to 12 to gnd 18 tx(max 232) 17 rx(max232) 16 +5v (usb) 15 tx(usb) 10 rx (usb) wbr |
Mehvishal thx for the pinout, can u give also for the usb cable, please ? |
24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 21 link to 2 19 link to 12 GND (GREEN and ORANGE, 7 and 8 from RJ45, and GND from USB) 18 tx(RED, 2 from RJ45) 17 rx(WHITE, 3 from RJ45) 16 +5v (USB) 15 USB Data + 10 USB Data - |
Do you have the cable diagram for UFS interface. |
Is this news or new??? |
You Are Using the OLD Original Software for U81x0 This is not a Redbox Soft |
yes it is not the REDBOX software. i am just trying to help people here to flash their u81xx phones without buying a seperate flasher cable. as redbox does not support unlocking od u8120 v105 i got problems to input codes. i the only solution is downgrade with FlashRW-040227-Multi-Release-SVC so i have modified the u81xx cable which comes with redbox and use the REDBOX only as interface... ( no soft from redbox can flash lg3g for now ). usb pinout http://forum.gsmhosting.com/vbb/show...ht=u8110+cable |
