Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SwS Team Products > Redbox
Old 06-25-2005, 04:58   #1 (permalink)
Mehvishal's Avatar
Member: 7482
Thanks Meter: 24
Flash u81xx with REDBOX NOW!!!1!
successfully flashed 4 u8120 today with redbox used as "max 232 interface"--- if i can say that
just modify cable u81xx by ADDING ONLY USB connections to it and use
FlashRW-040227-Multi-Release-SVC for flashing.
serial port, parallel port and usb port is connect to redbox.
works 100%
for owners of redbox...... no need to buy flasher cable to downgrade u81xx phones
WBR
Mehvishal
Old 06-25-2005, 05:05   #2 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
Red Box dont have usb port ! where did u attached the usb cable ? It has only one usb port for power supply in Red Box Mini Usb port !
Old 06-25-2005, 05:54   #3 (permalink)
Mehvishal's Avatar
Member: 7482
Thanks Meter: 24
use usb from your pc directly
Old 06-25-2005, 06:40   #4 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
Ok ! tell me pinout for 8120 !
Old 06-25-2005, 06:49   #5 (permalink)
Mehvishal's Avatar
Member: 7482
Thanks Meter: 24
Keyboard up
24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1
21 link to 2
19 link to 12 to gnd
18 tx(max 232)
17 rx(max232)
16 +5v (usb)
15 tx(usb)
10 rx (usb)
wbr
Old 06-25-2005, 10:37   #6 (permalink)
Member: 31246
Thanks Meter: 52
Mehvishal
thx for the pinout, can u give also for the usb cable, please ?
Old 06-25-2005, 11:07   #7 (permalink)
kenichi's Avatar
Member: 6084
Thanks Meter: 4
Originally Posted by Mehvishal
Keyboard up
21 link to 2
18 tx(max 232)
17 rx(max232)
16 +5v (usb)
15 tx(usb)
10 rx (usb)
wbr
Sorry, but not tx and rx on USB. is Data+ and Data-.
21 link to 2
19 link to 12 GND (GREEN and ORANGE, 7 and 8 from RJ45, and GND from USB)
18 tx(RED, 2 from RJ45)
17 rx(WHITE, 3 from RJ45)
16 +5v (USB)
15 USB Data +
10 USB Data -
Old 06-25-2005, 17:48   #8 (permalink)
Member: 41256
Thanks Meter: 74
Do you have the cable diagram for UFS interface.
Old 06-25-2005, 23:29   #9 (permalink)
eko
eko's Avatar
Member: 30098
Thanks Meter: 29
Is this news or new???
Old 06-25-2005, 23:31   #10 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 420
You Are Using the OLD Original Software for U81x0
This is not a Redbox Soft
Old 06-26-2005, 04:49   #11 (permalink)
Mehvishal's Avatar
Member: 7482
Thanks Meter: 24
yes it is not the REDBOX software. i am just trying to help people here to flash their u81xx phones without buying a seperate flasher cable.
as redbox does not support unlocking od u8120 v105 i got problems to input codes. i the only solution is downgrade with FlashRW-040227-Multi-Release-SVC
so i have modified the u81xx cable which comes with redbox and use the REDBOX only as interface... ( no soft from redbox can flash lg3g for now ).
usb pinout
LG 8110 flash cable
flashing n223i with redbox???? servtelgsm Redbox 17 05-18-2007 04:24
Flashed T809 with 820 now phone is dead. Shocker00 Samsung Flashers, Software, Firmware. 1 06-01-2006 05:37
w800i flashed chinese with cruiser, now no signal. davidliu21 Cruiser Suite 1 11-29-2005 20:40
flashing N22i with redbox problem .::Moby World::. Redbox 8 08-07-2005 16:13
@@@big Problem For Flashing M300 With [email protected]@@ zine Redbox 2 04-05-2005 21:04
Page generated in 0.35899 seconds with 8 queries
