help how to unlock GX-15 on redbox hey guys im a new user of the redbox...can anyone help me how to unlock sharp GX-15......????any help will be apreciated....thanks |
instal select com port select model and unlock next info in program regards |
hey garfield if i under stand you correctly i will use usb cable for unlocking gx-15?can you pls state some procedures clearly this is my first tym to unlock sharp using redbox...thanks man |
Its a big hassel to unlock GX15 with REDBOX ....just use Furious craked soft....the most easy way to unlock it.:):) |
ya farious is more easy but if you wanna unlock it on red box just follow program instruction |
you can use nec n525 usb cable install the drivers for sharp gx15 from device manger see the correct com then open the soft select com press unlock and format the phone its be unlocked 100% |
It's work with Usb cable or com cable? |
Best regards |
thanks guys already unlock it using movilcom drivers and the crack furios software.....thanks for the reply |
